winter steel wheel for the cobalt SS 2.0
Old Oct 9, 2005 | 10:08 AM
Katmanblues's Avatar
I'm trying to replace my 18'' P-Zero for the winter with 16'' steel wheels
Anyone can point me to a manufacturer's name and/or part number for a 16'' steel wheel that will fit my 2006 Cobalt SS they are hard to find in Canada
Thanks
Old Oct 9, 2005 | 03:27 PM
Malaclypse's Avatar
Tell me the bolt pattern and I can tell you if one is widely available (probably so).
Old Oct 9, 2005 | 06:44 PM
myoshizawa819's Avatar
Bolt pattern is 5-110.
Old Oct 9, 2005 | 06:51 PM
alleycat58's Avatar
Good luck with your search, most places are sold out of them now, but keep looking I'm sure someone has the right wheels.
Old Oct 9, 2005 | 07:01 PM
Malaclypse's Avatar
5X110.... I can't say I've ever heard of that bolt pattern before.. GM and their speshul enginurring. Its retarded!
At least the LS and LT models get a bolt pattern common to every import in exsistance. =p
Old Oct 11, 2005 | 12:01 AM
moved to drivetrain. how to is for posting instruction on how to do common tasks only.
Old Oct 15, 2005 | 10:17 AM
Steel wheel that fit on the SS/SC
Finally went this morning to try 2 sets of the 16'' wheels listed for the Cobalt SS here is the result
Palmer 99-128 at 59.99 DO NOT FIT
MACPECK X41658 GOOD FIT BUT THIGHT...stock calipers are very close...but since I only got 5000 km on it there shouldn't be any problem when I replace the front pads.
so I went with these rims at $82 and with the Dunlop M3.
Hope this can help someone...
Old Oct 31, 2005 | 11:44 AM
SSBlondie's Avatar
You want a tight fit! As long as they don't rub against the calipers, you want them tight.
The Palmers are 5 X 114.3, and our bolt pattern is 5 X 110. The Macpecks are X 110. And watch out, just because a set of rims 'don't fit' doesn't mean they won't put them on your car!!! It's happend Also, don't bother going to GM, they make a no-name rim but haven't made any for the SS/SC.
Hope this helps too!
Old Oct 31, 2005 | 12:02 PM
RiCeEaTeR05SS's Avatar
links to where I can buy? thank you
Old Oct 31, 2005 | 12:22 PM
dimeo09's Avatar
www.tirerack.com
Put your car in as a Saab 9-3 2 door coupe(same lug pattern)
and pick out some 16" wheels and tires(215 60R16) somewhere around that
your welcome
ps: do a little searching i found wheels at $75 each and winter tires at $62 each
...thats pretty cheap
Turbo6
Sep 24, 2015 04:15 PM
tamadrummer
Sep 23, 2015 02:26 PM
tamadrummer
Wheels and Tires
Sep 11, 2015 02:47 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
