Pedal cover problems. Anyone having any?
Old Oct 9, 2005 | 10:40 PM
CrateEngineDepot's Avatar
Hi, I have a customer with a complaint that the pedal covers they bought are causing problems with the brake light coming and the cruise deactivation due to the extra weight of the covers. Has anyone had this problem and if so were you able to correct the situation?
Old Oct 9, 2005 | 10:43 PM
Chevypowered's Avatar
sounds sketchy to me they can't weigh that much more, which kind are they?
Old Oct 9, 2005 | 10:44 PM
they are the GM accessory pedals.
Old Oct 9, 2005 | 10:51 PM
something you might be able to to is weight them and compare them to the stock ones. It doesn't seem like a true story. It caould also be their pedal sensors or srpings that aren't doing their job properly. Just my thoughts on it.
Old Oct 9, 2005 | 11:01 PM
Malaclypse's Avatar
Make sure the customer isn't riding the clutch as well if its a manual. These cars have a clutch anticipation switch that kicks off the cruise IIRC.
I seriously doubt pedal covers are causing this.
Old Oct 9, 2005 | 11:05 PM
philco_3's Avatar
Proud Playstation 3 Owner
i have no problem with them, installed them myself. there is little to no weight differnce in between the stock pads and the gm accessory ones.
Old Oct 10, 2005 | 12:01 AM
Clmbngfrk18's Avatar
no that won't cause the brake light to come on that's for the e-brake its a cobalt thing from what ive relized alot of people are havig that problem it happened to me a couple times it just blink on for a sec and goes off heard a little about chevy might be correcting it
Old Oct 10, 2005 | 06:44 AM
SilverSS/SC's Avatar
Ive got the GM aluminum pedals , and 0 problems for me . Like was said before , theres virtually no weight diff at all .
Old Oct 10, 2005 | 08:52 AM
Halfcent's Avatar
I'm old school
Tell him to quit dragging his foot against the brake pedal while driving.
Old Oct 10, 2005 | 09:47 AM
Thanks everyone, I will be contacting TAC today and douple check what problems they are having as well if they have a fix for it.
Old Oct 12, 2005 | 10:49 AM
RaineMan's Avatar
I put the pedal covers on myself.... no problems here.
Old Oct 12, 2005 | 10:46 PM
Woodio's Avatar
You can hear the sensor in the clutch pedal kick in about 75% of the way down. I would only really see the brake pedal cover causing the problem.
Old Oct 12, 2005 | 11:19 PM
italstalnprd86's Avatar
I had one problem when i put the brake one on, the lever that controls the breaks came un alined, and my breaks where sticking...... took it down to the shop and they re adjusted it and no problems ever since........
Old Oct 13, 2005 | 01:17 PM
player_1's Avatar
I've had no problems with my pedals.
except for putting those damn things on. what a pain
Old Oct 13, 2005 | 01:31 PM
NJBLUESS's Avatar
The pedal covers are not at fault. The Red brake light coming on is a programing fault in the IPC( instument panel console). The cruise deactination may be caused by the brake switch being out of adjustment. I have had a few compiants on Cobalts and HHRs for this.
Old Oct 14, 2005 | 12:19 PM
brianfcp's Avatar
i always wanted the pedals, but it looks like too much work to install em.
seems some people have the problem, and some dont.
Oct 27, 2015 01:27 PM
HEATON
Oct 16, 2015 07:21 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
SlowSaturn
Sep 28, 2015 11:03 AM
c_m_shooter
Sep 27, 2015 04:40 PM
