my recommendation if you plan on buying zzp header/dp
Old Jul 31, 2007 | 01:36 PM
DSMissed's Avatar
It will come with 2 bolts to go between the header and downpipe....go get your own grade A bolts. It took less than a day on my car for these bolts to snap, and I didn't over torque them, cause come on - I'm a girl I'm not that strong, lol.
Other than that, I'm in love excellent buy, just save yourself some extra hassle and get a couple of better bolts.
Old Sep 5, 2007 | 08:24 PM
MaJ's Avatar
MaJ
Very good advice!!
I was out driving for not even 10 minutes when I snapped a bolt.
Seriously, anyone who picks this up, get better bolts.
Other then that, the product is top notch! Very clean, well made product.
Old Sep 6, 2007 | 11:37 AM
NightriderCobaltSS's Avatar
ok i got the gmpp header and the zzp 2.5 i can still use the bolts that are already on there right
Old Sep 7, 2007 | 01:15 PM
MaJ's Avatar
MaJ
Yeah, if I remember correctly the GMPP header calls for you to reuse the stock bolts, correct? If that's the case, you shouldn't have any problems.
Old Sep 7, 2007 | 03:27 PM
thanks i have heard , the zzp dp is gonna get me some good gains. ill update when i get it installed
Old Sep 7, 2007 | 04:06 PM
RedEcotecSS's Avatar
my bolts took a **** too. got new ones, and i love it.
Old Sep 9, 2007 | 12:36 PM
zay52790's Avatar
has anyones been leaking, my bolts broke so i replaced them, it sounded like it was still leaking so i went and tightned all the bolts, everything seems good but it still sounds like its leaking.. has this happened to anone else?
Old Sep 9, 2007 | 12:40 PM
what do you mean 'it sounds like it's leaking'
Old Sep 9, 2007 | 03:38 PM
zay52790's Avatar
well , it sounds one hell of alot louder than it should and u can hear that the sound is coming from under the car near the front,
Old Sep 9, 2007 | 03:53 PM
Doc's Avatar
Doc
Get underneath the car while its on and feel around the flange. Just don't touch the pipe.
Old Sep 9, 2007 | 04:53 PM
OrngBalt's Avatar
how do you feel without touching?
Old Sep 9, 2007 | 05:01 PM
zay52790's Avatar
what should i be looking for about the flange, everything seemed fine, i checked yesterday and the flange is on properly an the bolts are tight
Old Sep 9, 2007 | 05:05 PM
HickOverLOrd's Avatar
You should feel hot air stream out from somewhere around the flange if you do have a leak.
Old Sep 9, 2007 | 05:31 PM
Doc's Avatar
Doc
ask your girl, she's a pro j/p
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
Sep 26, 2015 06:44 PM
