improvements on our a/w ic??
Old Nov 17, 2005 | 01:40 PM
Rusty's Avatar
I did a lot of research on our s/c setup with the air to water ic. i have always worked with a/a intercoolers, and so I had to learn some new things. I have heard that some people have put in a cold water reservoir in the trunk and routed the a/w ic there so that the intake temps are SUPER low. Has anyone else heard of this or know anything about this? I think this would be a sick mod....especially combined with the stage 1 and stage 2 kit, intake and exhaust
Old Nov 17, 2005 | 01:59 PM
R33P3R007's Avatar
360 L337 User
can't say I have heard, but I would be interested in learning about this.
Old Nov 17, 2005 | 03:06 PM
Hello's Avatar
Rusty I think you are thinking of water to air IC's, which are only good at the strip. You must fill them with cold water and ice, and some guys even use dry ice for even more of a cooling effect. Eventually the ice melts and the water warms and the cooling effect is lost, so as Im sure you can imagine it is not a good option for a street car. Also, I havent seen them mounted in the trunk. Seeing as how this type of IC is primarily used on on track cars that dont have passenger seats, the resevoir and IC unit is usually mounted in the cockpit where the passenger seat would be.
Hope this clears that up for you
Old Nov 17, 2005 | 03:20 PM
Rusty's Avatar
don't our cars have water to air (or air to water) intercoolers? aren't they the same (a/w w/a)? if that option is too extreme then for street use, what upgrade options are available for our intercoolers?
Old Nov 17, 2005 | 04:28 PM
Hello's Avatar
I could be wrong but I thought air to water and water to air were different. Regardless, the one you are thinking of, which is the same one I explained, are the same. At the moment I do not believe there is anything you can upgrade in the intercooler system for the LSJ. Only thing I could think of would be some kind of higher capacity tubing and the radiator for the IC coolant, but thats it. The LSJ might not even need an upgraded IC system at the moment. Has anyone done any hardcore testing of the IC in the LSJ to test output temps and what not?
Old Nov 17, 2005 | 06:22 PM
littless's Avatar
i am currenty building the resverve tank for mine. it will be placed be hind the front bumper. i did the exact same thing to my alero with great results. the tank will hold an addtional 2 gallons plus the 2 quarts the system already holds. the only option i won't have will being able to add ice.
Old Nov 17, 2005 | 06:32 PM
Brian MP5T's Avatar
I think any HP gains would be nulled out by the weight...
If you want to do that, just before a Drag race, hit the Water to Air intercooler radiator with a CO2 Fire Extinguisher. It will Freeze the coolant in the system and give you colder intake temp for your run...
No F-ing around with Coolant
No F-ing around with the warranty
EDIT: Ok, the word Freeze above was a bad term, "Make Cooler"
Old Nov 17, 2005 | 07:24 PM
I suggest you read the GM Perf division 300 HP LSJ build up. With some mods to the intercooler you can increase it's effectivness quite a bit acorrding to GM Perf Division. They go into little detail however.
Basically if you pass the water through the intercooler twice before returning it to the radiator it works better than the singe pass system.
Old Nov 17, 2005 | 07:25 PM
Brian MP5T's Avatar
Why not run water wetter, double drive the pump and put a fan on the IC radiator...
Old Nov 17, 2005 | 07:33 PM
Well I can't run water wetter right now cause it's getting below freezing, good idea tho.
The IC radiator is inbetween the A/C condenser and the Engine Radiator and there is electric fans on both.
The increasing the pump idea is a good one.
Right not my intake temps are only 30 degrees over ambient, not sure how much cooler I can get them.
Old Nov 17, 2005 | 07:35 PM
Brian MP5T's Avatar
NX Fogger
Co2 Fogger
Old Nov 17, 2005 | 08:43 PM
Cobalt_Supercharged's Avatar
If you put a higher flow pump, wouldn't that give the coolant less time to cool in the radiator?
Old Nov 18, 2005 | 09:42 PM
Brian MP5T's Avatar
Yes, but the coolant would cycle twice as fast as well, Put a second cooler in line there and it's solved..
Old Nov 18, 2005 | 10:47 PM
hennessey833's Avatar
Are there going to be an FMIC's coming out any time?
Old Nov 18, 2005 | 10:57 PM
Brian MP5T's Avatar
That would be some interesting Plumbing.
Old Nov 18, 2005 | 11:17 PM
Ours is a FMIC. If your talking a air-air box IC, like the EVO, you would have to do some very interesting plumbing. For all the trouble it would be to convert just the IC, it would be easier to go turbo or centrifigal S/C to get the a/a FMIC.
Old Nov 19, 2005 | 05:49 PM
GTPsRule's Avatar
Ours is a FMIC.
No its not. Your "FMIC" is nothing but a radiator for the IC coolant. The only intercooler on the SS/SC is in the intake manifold.
And screw that AC condensor bullshit. If I owned an SS I would quickly change that around and put the IC radiator in front of the AC condensor. Typical GM, stupid asshats
Old Nov 19, 2005 | 06:39 PM
Oops. I get confused with the w/a having an Intercooler and Aftercooler. My mistake.
Old Nov 20, 2005 | 02:21 PM
Rusty's Avatar
thanks for all the information guys. i am still learning about how our intercoolers work...its still new to me. anyway, my last question now is does anybody know how efficient it is? what i want to know is if i get the stage 1 and stage 2 kits, add a cai, and exhaust, will the air intake temps still be cooled enough for a quarter mile pass? or will it heat soak? any information on this would be appreciated. thanks!
Old Nov 20, 2005 | 03:58 PM
It should be. If not buy some dry ice and make a box to hold it on the IC's heat exchanger. (it's the middle radiator in the front)
Old Dec 18, 2005 | 04:23 PM
BooSSted's Avatar
The best and cheapest thing to do will be to move your heat exchanger for the IC to the front of the AC condenser. That way you will get more airflow through the heat exchanger and get better cooling for the fluid going to the manifold. I havn't really looked into how easy it would be to switch around but I can't see it being that hard.
Old Dec 18, 2005 | 04:33 PM
J.D.'s Avatar
I've been thinking about doing exactly this- any idea what it would involve? Anybody???
OrangeCoba
Sep 29, 2015 03:56 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
63 Nova SS
Sep 12, 2015 11:21 PM
medic710
Sep 6, 2015 08:53 PM
RedCavyRS99
Sep 13, 2004 08:17 PM
