Magnaflow
Old Nov 25, 2005 | 02:09 PM
MARIN007's Avatar
Canada Magnaflow
hey guys,
im looking for a full magnaflow exhaust and cat system for me '06 SS non-sc 2.4L
any advice is appreciated, and if it needs to be shiped it must be shipable to Canada.
Cheers
Old Nov 25, 2005 | 02:13 PM
helty's Avatar
go to magnaflow's web-site. see if they have one for your application. if so write down the part-number. they have a link that lists a bunch of magnaflow dealers. shop around and you will find the best deal.
EDIT: i just checked. they have systems for the I-4 2.0 and 2.2L, but no 2.4. you could just weld in some mufflers until a system for the 2.4 comes out. here's the link
http://www.magnaflow.com/02product/s...455&cat=Cobalt
and for that price, i'd go with weld-ins.
Old Nov 25, 2005 | 06:24 PM
MARIN007's Avatar
i would go with a weld in, but then after some time ill have to saw it off, and its a leased car. is there any bolt on solution? someone on this forum must be leasing too right?
Old Nov 26, 2005 | 12:53 AM
stlurbanpunk's Avatar
I hope it sound better than the 2.2 snd 2.0 ones on there.
All i have to say is the subaru (2.5) one sounds nice!
Old Nov 26, 2005 | 01:05 AM
97cavie24ls's Avatar
as far as i know the 2.4 and 2.0 share the same cat back
Old Nov 26, 2005 | 02:19 PM
ninja44's Avatar
Originally Posted by MARIN007
hey guys,
Cheers
Hey Marin, I just got off the phone with my buddy Rick at Don Howson and he asked me for the # of the place my exhaust came from. I was reading the forums when he called and I saw this post and mentioned your user name and it was you lol. He'll be giving you a call with the info and if you have any more Q's PM me.
Old Nov 28, 2005 | 10:33 AM
celicacobalt's Avatar
they have the 2.4 listed on the site look again
Old Dec 4, 2005 | 07:02 AM
biggsSS's Avatar
Only the 2.2L and the 2.0L are listed... I don't see 2.4
Old Dec 5, 2005 | 09:33 AM
when i go there i can see it its on the same page as the 2.2
Old Dec 6, 2005 | 09:36 AM
MARIN007's Avatar
someone put up a link cause all Im seeing is the 2.0 and 2.2 2005. I have mine on the way already but I never did find the right link, just called Magnaflow
Old Dec 6, 2005 | 10:01 AM
New, Now Available!!!
2.0L I-4 Supercharged, Cobalt SS, Sedan,
2.5" SS tubing, 4" rolled/slash/p-SS tip
they changed it from what it said before but basically when they say sedan right here the only sedan is a 2.4 ss so we share the same exhaust with the s/c ss
Old Dec 7, 2005 | 11:43 AM
averagewhiteboy's Avatar
As a general rule of thumb, a full cat back is always considered better than just a weld on. The sound will also be a bit deeper with a full cat back I believe. However, our 2.4 SS's already have descent size diamerter tubing. Plus, the cars are still too new to have any piping rot. That'll hinder performance. Thus you could certianly get by with just a muffler, but a cat back would be slightly more advantageous. But you have to ask yourself. Do you want to spend like 500+ for a cat back...or would you be happy with spending 200 or less for JUST a muffler? That part's up to you.
On my Monte I had 2 Dynomax mufflers welded on directly were the stockers were. On my Cadillac, I had a Dynomax welded on in the stock place as well. And on My Accord, I welded on a Ractive muffler. The sound it's self was irrelevent. Irrelevent on any of them. But my point is on all of my cars, I got by just fine with only mufflers.
The last thing is too... How much sound do you want? Actual sound output. On my Accord, I put a Ractive Fireball "canister" muffler. Personally, I think it was a respectable muffler, in terms of canister mufflers. Not annoyingly loud (except on the highway cruising at high speeds even in 5th gear) by any means. On the Cadillac, I only added one muffler. There only was one stock one (not Northstar, just 4.5). The sound output was almost stock. But the idle was the glorious V8 burble I was looking for. But for the Monte, it had 2 mufflers. So it was obviously slightly louder than the Monte LS's single muffler. Mine's the SS wit hthe 3.8 and dualies. Not TRUE duals, but it has a Y pipe, then 2 mufflers and tips. So I replaced the mufflers with 2 Dynomax Super-Turbos (same as I used on the DeVille) and used the OEM offsets and diameter. I also used 2 chrome tips to give it some flair. The car IMO sounds great. It doesn't quite have the "tinny" sound of a Grand Prix GT / GTP, but it's certainly not a 350 either. It sounds great it idle (maybe compare it to a stock 305), then sounds like a deeper stock Monte SS at speed. It's really nice. The only time it's horrible is when you're going up a hill and NOT flooring it. Then it drops in revs and gets really droney. But then you just step on it and it's gone. lol.
But personally, I like how the stock 2.4 exhaust sounds. I like the idle. I just want a little more sound when accelerating. Even a stock sound...but just a little louder. If I'm driving a 4 cylinder, I don't expect it to sound like a 350. So I don't care.
Sorry for rambling. lol...
Old Dec 7, 2005 | 11:54 AM
Mikecobalt's Avatar
I'm leasing my car and I have put a magnaflow exhaust on it, wweld on it by my dealership so no worries as to waranty issues...
Old Dec 7, 2005 | 02:26 PM
Brandon97Z's Avatar
I'd say go the exhaust shop route. Getcha a muffler & resonator (if you don't want it loud) of choice and have a shop bend the pipe and install everything for 300.
Old Dec 7, 2005 | 06:38 PM
I got my Cadillac done, including Dynomax Super-Turbo, at Minekie for like $120-ish I believe.
The monte (since there were 2), including the same mufflers, cost me $160-ish, also at Minekie.
Thus, if you just get a universal muffler, plus resonator if you'd like, it'd be less than $150 probably, at Minekie. That's if you buy a Dynomax Super-Turbo for $40. A canister style muffler would run more like $100+ for anything worth a crap.
Old Dec 15, 2005 | 10:09 AM
MARIN007's Avatar
Thumbs up Its On!!!
Hey guys, yesterday at noon a FedEx truck came to my door. I recieved a big ass box containing my Mangaflow catback exhaust. Unfortunatly for me, I was at work 'til 2pm, but when I got out I gunned it home. It was nicely polished 2.25inch piping. I opened it, then closed it, barely got 3/4 of the thing in my trunk and headed for Pipes Performance Exhaust at Warden south of Eglinton. I get there and buddy told me $70 flat and it would be done in an hour. It was 2:30pm and I had to teach tennis from 4-6. They close at 6! Being the impatient baby that I am, I asked a friend to go pay the man $80 since he was going to have it done so soon (Im good like that). So finally 6pm rolls around and my friend picked me up in his recently turboed Nissan 240sx. Needless to say there was a lot of intentional drifting on the way there! So we get there, and it looks sooooo stock. Only after closer inspection can you tell its slightly different. We sit in the car and I turn it on. *drool* The instant quick little rev from the startup gave me a warm fuzzy feeling inside. At idle, you can barely notice the slightly lower hum. I went outside and let my friend give it a few revs. HOLY SH*T it sounded nice, very similar to something youd hear in Need For Speed: Most Wanted (thats the closest comparison I could think of). There is no Honda rice sound so dont worry.
So overall, I say it was a good buy and great mod for me and for anyone else who wants to try it. Thanks for putting up with my long @$$ story, it almost makes you feel like you were there doesnt it?
Old Dec 15, 2005 | 11:30 AM
thats cool glad you like it
Old Dec 15, 2005 | 11:37 AM
I like this:
*drools*
Bwahahahaha!!!!!
Yo man, we NEED sound clips. Like right now. Your acount will be postponed until you do so.
:P
BTW: How much did that exhaust cost you? Without installation. Just the cat back plus shipping.
Old Dec 15, 2005 | 04:44 PM
Brandon97Z's Avatar
Also wanting to hear of any performance gains......
Old Dec 15, 2005 | 10:38 PM
ninja44's Avatar
Was I right or was I right?
Old Dec 16, 2005 | 09:59 AM
MARIN007's Avatar
I'll have to go with...YOU WERE SOOOO RIGHT
Old Dec 16, 2005 | 02:23 PM
Dragonsfire12345's Avatar
wouldn't the Pontiac solstice with the 2.4 sound the same as ours cuz magnaflow has it on there
Old Dec 17, 2005 | 11:50 PM
Yeppers.
And wow! I really like all 3 clips. both Cobalt ones and the Solstice. That exhaust sounds gooooood!!!!
Any installed pics on your 2.4? I want to see it!!!!!
Old Dec 18, 2005 | 12:57 AM
I like magnaflow, but I'm going with Borla.
Old Dec 18, 2005 | 01:33 PM
Get a clip and pics up of that too. We can compare. 2.4 exhaust compar-oooooooo.
