Tire psi?
Old Dec 8, 2005 | 06:08 PM
Cyrus the Virus's Avatar
Tire psi?
I have 16" machine face rims. On 2005 Mich. Tires. What Psi should I fill at for better fuel effic.
Thanks
C
Old Dec 8, 2005 | 06:12 PM
pclear9061's Avatar
max psi, then if you go to the track then drop to about 30 +/-
Old Dec 8, 2005 | 06:15 PM
pclear9061's Avatar
also make sure that you fill the tires up when they are cold, b/c if you fill them up when they are hot then when the tire cools down they will be at a lower psi then what you filled them up to.
IE:
you going around town for ~ 20 mins and realize that a tire seems low ~ 25 and max is 50, so you stop and fill to 50 lbs and then the next day you check again (after letting it sit overnight and cooling off) it would prob. be around 40 +/-
Old Dec 9, 2005 | 01:15 PM
Thanks
Thanks man..
Regards,
Cy
Sl0wbaltSS
Nov 21, 2018 11:11 PM
bigdeertz
Nov 17, 2016 09:41 AM
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
DANRICKARD
Oct 1, 2015 12:08 AM
