4 day intro sale on a new product line.. dont miss this!
A new product line that will be arriving on Tuesday. I am bringing English Custom Polishes on board. They are strictly a metals polishing company that has a great following with bike guys and show cars. These very well may some of the highest quality metal polishes out there. With that said, I put up a slight discount on these items that will last until Monday evening, at which point I'll return them to full retail. As of right now, you can obviously use your forum discount on them to reduce the price even further.
Heres what we got:
http://www.glimmerglassdetailing.com/encupo.html
http://www.englishcustompolishing.com/index.html
http://www.glimmerglassdetailing.com/mepore.html
Metal Polish & Restorer Aluminum Polish
TOUGHEST aluminum polish on the market. A good stainless or chrome polish too! Use Metal Polish and Restorer aluminum polish when your surface is dull, oxidized, acid or salt stained, rusted, neglected and in need of serious help, no other aluminum polish works like this restorer. It will bring your aluminum back to life and begin the foundation for a brilliant mirror in no time. It will remove heavy bluing and rust from chrome.
Ammonia and salt graying disappears from stainless
Easy to apply
Easy to remove
super economical
pH balanced to reduce re-oxidation
We recommend that you use this product first on all surfaces, unless you have a good mirror, before going on to our finishing blends.
250 ml liquid - flip top bottle
Metal Polish and Restorer is highly concentrated. Please use sparingly. Unlike most metal polishes, this product does not contain ammonia, any form of anhydrous chemical or acid, which may cause harm to your metal. Metal Polish and Restorer aluminum polish contains no waxes as these would reduce the cutting power.
We therefore recommend that you continue to polish with one of our finishing blends such as Showman's Blend aluminum and stainless polish to obtain a glorious mirror, and long lasting protection.
Metal Polish and Restorer aluminum polish will leave a finish suitable for good adhesion of clear coat, lacquer or glazes.
Metal polish and Restorer aluminum polish is pH. Neutral so you will not seal oxidizers into porous metals such as aluminum, brass, zinc, etc.
http://www.glimmerglassdetailing.com/showmansblend.html
Showman’s Blend stainless and aluminum polish
A stainless steel polish and aluminum polish in one.
This metal polish is astounding.
Achieve the finish others dream about.
Stainless steel and aluminum polish out to look like chrome with Showman's Blend stainless steel and aluminum polish
For a true Show quality finish and minimal maintenance there is nothing like this product:
-Easy to apply,
-Easy to remove,
-Super economical,
-Fantastic waxes and enhancers.
This is the finest stainless steel and aluminum polish on the market.
Super long lasting finish.
250 ml liquid - flip top bottle.
Showmans blend stainless steel and aluminum polish is highly concentrated. Please use sparingly. Unlike most metal polishes, this product does not contain ammonia, any form of anhydrous chemical or acid, which may cause harm to your metal. Showman's Blend Stainless and aluminum polish is pH. Neutral, so you will not seal oxidizers into porous metals such as aluminum, brass, etc.
On severely oxidized surfaces we recommend that you use Metal Polish and Restorer aluminum polish as a first step.
http://www.glimmerglassdetailing.com/customblend.html
Custom Blend Aluminum Polish
The ultimate aluminum polish.
Makes aluminum wheel polishing a breeze.
This aluminum polish was developed for competitive, concours quality vehicles and show winners.
Custom Blend will give your aluminum a super rich appearance, Your friends just won't believe it hasn't been chromed.
This aluminum polish will make aluminum so bright and silky smooth, It's sexy!!
It's simply the best polish you'll ever use.
It should only be used on pre-polished surfaces.
This product will not restore old and cruddy pieces unless you are prepared to rub a very, very long while, but it will make the best finish you can get, even better.
Custom Blend Aluminum polish is the winner's choice. pH neutral to ensure long life.
-Easy to apply,
-Easy to remove,
-Super economical,
-The finest aluminum polish on the market.
-Super long lasting, ultra-bright finish.
-250 ml liquid - flip top bottle.
-Custom blend aluminum polish is highly concentrated.
Please use sparingly. Unlike most aluminum polishes, Custom Blend does not contain ammonia, any form of anhydrous chemical or acid, which may cause harm to your metal. Custom Blend aluminum polish is pH. Neutral, so you will not seal oxidizers into porous castings.
Minimal amounts should be used for best results. Using more is not better. Using less is best!
We recommend that Custom Blend aluminum polish is used on show quality machines after they have been finished with Showmans stainless steel and aluminum polish and similar top quality finishes, and for maintenance of premium show quality vehicles.
http://www.glimmerglassdetailing.com/chandhotenpo.html
Chrome Polish and hot environment polish
Chrome Polish and hot environment is a superb chrome polish first and foremost.
It is good at removing bluing from chrome and gold from stainless exhausts.
Excellent polish for use on any metals that have to endure extreme heat
Ultra-fine, gentle abrasives won't scratch your chrome.
Chromium is generally only 18 to 30 millionths of an inch thick. The nickel you see shining underneath it, might be up to a thousandth. Don't polish your chrome away with coarse products. Our Chrome polish will make it gleam but won't hurt it.
-Easy to apply
-Easy to remove
-Super economical
-This is the finest chrome polish on the market.
-Super, long lasting finish.
-Super gentle.
Like all our products, it is pH balanced.
-250 ml liquid flip top bottle
-Hot environment and Chrome polish is highly concentrated.
Please use sparingly. Unlike most metal polishes, this product does not contain ammonia, any form of anhydrous chemical or acid, which may cause harm to your metal. Hot Environment and Chrome polish is pH. Neutral. It cannot harm your chrome or any other metal in any way.
Heres what we got:
Easy to apply
Easy to remove
super economical
-Easy to apply,
-Easy to remove,
-Super economical,
-Easy to apply,
-Easy to remove,
-Super economical,
-Easy to apply
-Easy to remove
-Super economical
-Super gentle.
