A Question
Old Feb 11, 2008 | 04:27 PM
HawkMThe's Avatar
A Question
Could I put a supercharged manifold on my SS?NA and if so would there be any performance gains??
Old Feb 11, 2008 | 04:30 PM
Co|3aLt $$'s Avatar
not without a TB adaptor...which I think would be difficult...and maybe with some porting but I can't imagine much...
also...wonder about the saab turbo intake manifold? though it might be too big, i'm not sure.
Last edited by Co|3aLt $$; Feb 11, 2008 at 04:30 PM. Reason: Automerged Doublepost
Old Feb 11, 2008 | 04:37 PM
OrngBalt's Avatar
If I am correct, isnt the SC manifold made of metal? You might infact see a decrease in performace due to weight. It wouldnt make much sense to do it without putting the SC on there. and yes... you would need either a TB adaptor or an SC TB
Old Feb 11, 2008 | 04:39 PM
Drakonen2000's Avatar
ok, issue, our manifold has an intercooler built in, its a biiiig honkin chuck of metal...and the supercharger sets right on it, so there would be no way in hell to adapt a filter fitting for it unless you like to do aloooot of custom work for something that would be pretty much pointless...
Old Feb 11, 2008 | 04:54 PM
Evil C's Avatar
That and metal is a bigger conductor to heat than the plastic so you would have that much hotter air entering the engine.
Old Feb 12, 2008 | 11:36 AM
BennyHHR's Avatar
Yep, if you put the S/C on the manifold!
Old Feb 14, 2008 | 08:48 AM
HawkMThe's Avatar
Thx I know this is off topic but would it help alil with performance if I put a Hyper Ground Voltage System on??
Old Feb 14, 2008 | 08:59 AM
OrngBalt's Avatar
is that a grounding kit? no... they are worthless on these cars.
Old Feb 15, 2008 | 11:21 PM
WhiteSSBalt's Avatar
Not a Sebring
Benny man, where have YOU been???
Old Feb 15, 2008 | 11:39 PM
mike25's Avatar
putting a sc manifold on wouldnt really do a whole lot for you...its already not got alot of capacity due to poor design...pick up a 9-5 turbo intake mani or a cobat ss tc mani when it comes out...the only difference between ours and the ss tc mani would be thats ours is composite plastic and thaeres is made of metal....which is good for higher boost levels...that is if your even talking about the intake side..
brandon04
Oct 21, 2015 07:04 AM
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
