steelies
Old Dec 15, 2005 | 12:08 PM
mcphatty's Avatar
steelies
i've been hearing a lot about the 16" steelies are too small for the SS's, that they hit the brake caliper or something like that. are there any steel wheels out there that'll fit without rubbing? and what size tires should i throw on them? im lookin to get a set of snow tires, because getting stuck on my flat driveway is getting just plain annoying.
Old Dec 15, 2005 | 12:12 PM
p7x's Avatar
p7x
I have also heard that and have been told that, but its BS!!! i have 16 inch steelies on with 205/60/16 BFG winter saloms on. 16 is the smallest u can go and looking at my wheels there is barely room between the rim and the brake caliper but i have not had any problems.
Old Dec 15, 2005 | 01:12 PM
RedBaseBolt's Avatar
I would think 17inch steelies would be kinda expensive anyways
Old Dec 15, 2005 | 01:13 PM
You could always check with Dodge, they make 17inch steelies for the Gay version of the Charger. I don't know about the bolt patttern though...just a though.
Old Dec 15, 2005 | 01:22 PM
Hutch's Avatar
Canada
Don't forget that dropping down from 18's to 16's will throw your actual mph/kmh off. If the factory set your speedometer to say 60mph on 18's then with 16's your actually going 54 mph.
Hutch
Old Dec 15, 2005 | 01:31 PM
alleycat58's Avatar
Hutch
That doesn't depend on the wheel size it depends on the overall diameter of the tire. My speedo is only off by .2 miles per hour. When it says I'm going 60mph I'm really going 60.2mph, it's slow because my snow tires are .1" bigger than stock in overall diameter.
As far as the 16" steelies, you should be fine, mcphatty. I have 16" G6 rims on and they fit perfect.
Old Dec 15, 2005 | 01:51 PM
ericsean's Avatar
I bought the 16in steel wheels from tirerack, and they fit just fine.
Old Dec 15, 2005 | 01:54 PM
c7015's Avatar
I have 16" steelies on my car too ..you will be fine ...
also it wont change your speedo/km if you get proper sized tires
though all of these questions have been discussed ALOT there is even a tire section in the "how to" section
Old Dec 15, 2005 | 01:56 PM
plyboy-illest's Avatar
i have 16 as well and no rubbing ...
Old Dec 15, 2005 | 01:59 PM
R33P3R007's Avatar
360 L337 User
yup, but it may be too late to get steelies. they were sold out in our bolt pattern everywhere I looked.
Old Dec 15, 2005 | 04:36 PM
Hutch's Avatar
Smile
Good catch alleycat58. My mistake on calculations. Shouold have calculated 215 45r 18 (original tire) and did 215 60r 18.
Big difference.
Hutch
Old Dec 15, 2005 | 04:47 PM
bdwarr6's Avatar
how much do stealies run, and how about slicks?
Old Dec 15, 2005 | 07:35 PM
05_Blue_B10WN_SS's Avatar
Good luck finding a pair of "cheap slicks that fit a 16" rim. They are an oddball size. commom slick size is 15" so we are kinda screwed.
dieGone
Sep 23, 2015 10:20 AM
BlackLSJ
Wheels and Tires
Feb 24, 2007 10:38 AM
biohazard
Wheels and Tires
24
Jan 11, 2007 10:19 AM
FLM1
Dec 2, 2006 10:10 PM
farfrmnormal
Oct 25, 2006 03:31 PM
