Smooth Flow Pulleys Smooth Flow Pulleys is a Supporting Vendor of CobaltSS.net
Contacts: nherbst454
what's needed
Old Feb 18, 2008 | 07:14 PM
n8g's Avatar
n8g
what's needed
I'm piecing together my own "Stage" kit. I want to use your 2.9 pulley. I'm stock right now. What additional parts do I need besides the pulley and new screws to get the factory pulley off and get your pulley on? Do I need a pulley puller or a different snout? Thanks in advance.
Old Feb 20, 2008 | 10:25 AM
n8g's Avatar
n8g
Question answered.
If you're currently stock what you'll need is a complete modular pulley system and a puller/install tool...here are the links...
Complete modular pulley system on the bottom half of the page
www.smoothflowpulleys.com/Stage2.html
Pulley Puller/Install Tool
http://www.smoothflowpulleys.com/Pulley_Puller.html
You don't need a new snout, the pulley system hub is pressed on the same way as the stock pulley so all you need to do is use the puller to remove the stock pulley, then use the threaded shaft/nut assembly to press the new hub on.
Thanks for your interest!
Old Feb 28, 2008 | 04:59 PM
n8g's Avatar
n8g
Pulley and hub ordered.
DarrenGC
Dec 24, 2021 01:55 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
