08 Recall
Old Feb 22, 2008 | 11:30 PM
Vilkacis's Avatar
08 Recall
well i just got a recall notice for my 08 LS. apparently theres a coolant leak problem...o well now i gotta go to a chevy dealer.
Old Feb 22, 2008 | 11:32 PM
Sunburst_SS's Avatar
yea, I actually did one at work today. It's to have a second hose clamp installed on the thermostat housing on the coolant hose from the jug to the thermostat housing.
Old Feb 22, 2008 | 11:34 PM
Vilkacis's Avatar
well thats lame. how long does that usually take
Old Feb 22, 2008 | 11:35 PM
chris88z24's Avatar
Make sure they don't take your car drifting in the snow and ram it into anything like they did with mine. Other than that you should be O.K.
well, once the car is actually in the shop...it takes like 5 minutes.
Old Feb 22, 2008 | 11:38 PM
Immortal Technique's Avatar
Tried just driving in the snow today in ct, and when I nearly slid into a curb, I put it away and drifted with dads car instead.
Firebirdhorn's Avatar
LOL....I'm sorry to hear about your car man.....
Also, I hope mine doesnt have this problem, I am supposed to get it tuesday!
Old Feb 22, 2008 | 11:41 PM
chris88z24's Avatar
It's getting it to the shop is what you have to worry about. A lot of damage can happen between where you park and there apparently. Over 4 grand worth!!
Old Feb 23, 2008 | 12:13 AM
GTO 1's Avatar
Is it all....
Is it just the 2008's getting recalled? Is it just the 2.2's? I didn't get anything (yet).
Old Feb 23, 2008 | 12:16 AM
I dunno....in all my years working at a dealership, I've managed not to mess up anyones car.....but eh I guess accidents do happen. As long as they weren't doing things they shouldn't of been anyways
Old Feb 23, 2008 | 09:38 AM
Blue_Balt's Avatar
I didn't get anything either.
Old Feb 23, 2008 | 09:48 AM
rmorris003's Avatar
i didnt get anything yet either for my 08 sport 2.4
Old Feb 26, 2008 | 07:46 PM
GTO 1's Avatar
This is it guys... (and gals)
#07255: Customer Satisfaction -- Coolant Leak - (Oct 4, 2007)
Subject:07255 -- Coolant Leak
Models: 2008 Chevrolet Cobalt
2008 Pontiac G5
THIS PROGRAM IS IN EFFECT UNTIL OCTOBER 31, 2008.
Condition
On certain 2008 model year Chevrolet Cobalt and Pontiac G5 vehicles, the hose connecting the surge tank to the thermostat cover may not seal sufficiently. This could result in a coolant leak at the thermostat cover. If enough coolant leaks out, the engine coolant temperature warning light will illuminate. If the vehicle is driven with the light illuminated, it could result in engine damage.
Correction
Dealers are to install an additional clamp to the hose at the thermostat cover.
Vehicles Involved
Involved are certain 2008 model year Chevrolet Cobalt and Pontiac G5 vehicles built within these VIN breakpoints:
2008 Chevrolet Cobalt 87100001--87125118
2008 Pontiac G5 87100006--87125081
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM Vehicle Inquiry System (GMVIS). Not all vehicles within the above breakpoints may be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided through the applicable system listed below. Dealers will not have a report available if they have no involved vehicles currently assigned.
-- US dealers - GM DealerWorld Recall Information
-- Canadian dealers - GMinfoNet Recall Reports
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
Parts required to complete this program are to be obtained from General Motors Service and Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
Part Number
11571080 Clamp, Rad Surge Tk Otlt Hose
12346290 - US Coolant, Eng (Extended Life) (DexCool)
10953464 - CN As Needed
Service Procedure
1. Remove the engine cover.
1.1. Unscrew the oil cap.
1.2. Pull upward on the cover to unseat the cover from the pins.
2. Open the spring clamp and push the hose fully down to the thermostat cover housing.
3. Install the hose clamp.
3.1. Open the hose clamp fully, disengaging the worm screw.
3.2. Slide the hose clamp over the surge tank outlet hose.
3.3. Hand-start the worm screw to engage the hose clamp over the hose.
3.4. Position the hose clamp along the top of the existing spring clamp. The screw head should be on the outboard side of the hose and facing forward.
3.5. Tighten the hose clamp. Keep the two clamps beside each other but with no overlap.
4. If the surge tank fluid level is below the cold full line, top it off to the line with coolant.
5. Wipe any spilled or leaked coolant from the engine and engine compartment.
6. Replace the engine cover.
6.1. Engage the two pins.
6.2. Replace the oil cap.
Old Apr 8, 2008 | 12:21 PM
Dunkinuts's Avatar
yeah i had that done when i got my oil changed this weekend. i was there about an hour for oil change tire rotation and the coolant fix. cost me 30 bucks
Old Apr 8, 2008 | 12:24 PM
SilvrLT's Avatar
SAME HERE
Old Apr 8, 2008 | 12:37 PM
Dunkinuts's Avatar
^^^ i have a 08 sport 2.4 i got mine in feb. (recall) bought the car in late nov.
Old Apr 8, 2008 | 01:17 PM
SilvrLT's Avatar
I bought mine in december
Old Apr 24, 2008 | 01:56 AM
Magill8's Avatar
Lol i chose to ignore this notice back in 04
In fact there was also a recall on my O-rings
Resulted in my tranny getting eatin, I had nothing left it was completely obliteratted. (SP)
Old Aug 18, 2008 | 08:38 PM
Shibito's Avatar
Just got my notice of this recall today and I bought the car 2 months ago...
satisfied
Oct 19, 2015 12:35 AM
southal cobalt
Sep 9, 2015 08:21 AM
