The OFFICIAL Coilover Thread
Ok, the other coilover thread needed a serious update. So I have compiled a list of all (or most) of the current available coilover systems along with info from the manufacturer on each one.
Everyone please feel free to post pictures and/or reviews on your coils because most people are going to want to 1) know how far they drop and 2) what your opinions are after owning them. Thanks guys
KW Variant 1 ~$1100-$1300
Optimally pre-set
Sporty harmonious damping technology
Stainless steel technology inox-line
Individually height-adjustable
Lowering range approved by the German Technical Control Board (TUV)
Fully finished complete solutions
High-quality component parts for long durability
Comprehensive documentation for easy use
The KW Variant 1 Coilover System is the ideal system for customers wishing to rely on the experience of our engineers for dampening yet determine their own degree of lowering. In extensive driving tests our engineers have set the dampers for the best balance between sporty driving, comfort and safety.
KW Variant 2 ~$1400-$1700
Variant 2 sporty and personalized with adjustable rebound damping
The system intended for the experienced driver who requires to not only determine the individual lowering of their vehicle, but adjust the damper setting to fine tune the system to their needs. The adjustable rebound damper allows adjustment of the pitch and roll behavior of the vehicle, adapting it to one‘s own driving preferences.
- Damping technology with individually adjustable rebound
- inox-line stainless steel technology
- Individually height adjustable
- German TUEV-tested adjustment parameters
- High-quality components for long life
- Comprehensive documentation for ease of use
- Infinitely adjustable rebound damping
Pedders SportsRyder XA ~$1500
Pedders SportsRyder brand has been synonymous with high performance dampers for decades. Pedders SportsRyder shock absorbers and struts combine the most advanced technology with Pedders? renowned expertise in the fine tuning of damping rates for superior handling while maintianing close to OEM ride quality. At the forefront of sports suspension is Pedders eXtreme XA, height adjustable coilover built to Pedders stringent quality standards. Pedders eXtreme XA features sports calibrated tunable damping, motorsport coil springs individually tuned to suit each application and a host of other high performance features including engineered OEM compatible bracket. The eXtreme XA is the pinnacle of performance suspension technology. Height adjustment is achieved by turning the entire coilover into the lower clevis. The 2mm preload on the coil remains the same regardless of height. The range of travel remains the same regardless of the installed height. As the spring perch is not the source of height adjustment and the spring preload remains the same, ride quality is identical at minimum drop and maximum drop. The Pedders Sports Ryder eXtreme XA adjustable coilover range features 30 Position Adjustable Bound and Rebound Damping with a positive CLICK. These are positive Click-to-Tune positions. There is no guess work or doubt as to the setting. You can feel each click as you adjust the damping.
Stance GR+ ~$1200-$1300
Spring Rates: 6k Front, 5k Rear
The GR+ is the Stance flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
Features
Adjustment Knob 15-Way Damping Adjustable
Upper Pillowball Bearing Adjustable Camber Uppermount
Upper Pillowball Bearing Pillowball Uppermount
Spring Cold Wound Linear Spring
Monotube Inverted Monotube Shocks
Boot Dustboot
Collar Aluminum Collars & Upper Mounts
Bracket Height Adjustable Lower Bracket
Ksport Kontrol Pro ~$1000
Spring Rates: 6k Front, 4k Rear
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability. The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Ksport GT Pro ~$1300-$1700
Spring Rates: 7.5k Front, 4k rear
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring an inverted monotube design, 36 levels of adjustable damping, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer. This design also reduces under-sprung weight, which improves handling and responsiveness.
Key Features:
Inverted steel shock absorber for durability
Lower center of gravity and higher chassis rigidity
Designed to reduce friction for cooler shock oil temperature
Inverted design like vehicles in WRC and all JGTC cars
36-way adjustable damping
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Mount Front: Pillowball Upper Mount
Mount Rear: Must re-use OEM mount
B&G RS2 ~$1100-$1300
B&G Coilovers are designed and produced exclusively by world class technicians. Each application combines race proven technology with the vehicles unique design characteristics for the ultimate in ride, handling, and comfort.
RS2 Coilovers put you in complete control with 18 levels of external dampening control (combination of Rebound and compression). Featuring monotube gas charge dampers for quick response and steering control, and a low bleed system to maintain ride quality during normal driving conditions. RS2 incorporates separate adjustments for damper length and spring perch height to allow extreme lowering with full shock travel. For street driving to occasional track use, RS2 Coilovers allow you to dial in the optimal ride height and dampening force for any driving environment.
Features
Adjusts height from 1-3.5 inches (Lowering may vary depending on application)
18 way adjustable dampening (combination of rebound and compression)
Monotube gas charge dampers
High strength anodized aluminum alloy and powder coated steel components
Full length height adjustment with separate settings for damper force and spring pre-tension
Limited Lifetime Warranty
Megan Racing Street ~$850-$1000
Spring Rates: 6k Front, 6k Rear
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 levels of damper force adjustment, separate spring perch height and shock length adjustment allowing you to retain full suspension stroke and to fine tune your suspension characteristics. These damper kits are then perfectly matched with front and rear Pillow Ball upper mounts, including camber plates integrated with the upper Pillow Ball mounts on strut-type suspension applications.
Features:
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
D2 Racing RS ~$950-$1200
Spring Rates: 7.5k Front, 4k Rear
The RS coilover system is a 36 way dampner and rebound adjustable monotube full coilover system. The setup has seperate height and preload adjustments allowing for optimal adjustment and allowing full strut travel at all times along with pillowball upper mounts or top mounts*. Mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
BC Racing BR
Our BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
- Mono-tube shock design
- 30 levels of damping force adjustment, adjust compression/rebound
- Pillowball mounts and adjustable camber plates included (where applicable)
- Adjustable rear camber plates available
- Separate full length height adjustable
- One year warranty
- Rebuildable
Ark DT-P ~$1300-$1500
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response.
All bolt on system
16-Level Adjustment
Street & Track Performance Spec
Pillow Ball Mount / Camber adjustment (Some application)
Mono-tube Shock design for quick reacting and quite dampening operations
Adjustable Ride height
Specially designed with JDM Racing Team
All 15months manufacture limited Warranty
Xtreme Quality makes Xtreme Performance
Ark ST-P ~$1400-$1500
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The Rubber Top absorber mounts ( ST-P only) also allow you a more soft comfort driver response than our DT-P . Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
All bolt on system
16-Level Adjustment
Street Comfort Performance Spec
Rubber Mount
I'm gonna keep editing this with more information, I'm sure I missed a bunch of stuff, feel free to let me know.
Optimally pre-set
Features
Boot Dustboot
Key Features:
Features
Features:
- Rubber Dust Boots
- Aluminum Brackets
BC Racing BR
- One year warranty
- Rebuildable
All bolt on system
16-Level Adjustment
All bolt on system
16-Level Adjustment
Rubber Mount
Zo6balt (01-15-2021)
great thread, yea as people send pics in (hopefully mostly side shots) you can add the pics under each setup? also, a ballpark pricing for each would be sweet. this is all for side by side comparisons, which most ppl probly wanna see, myself included. the more reviews we get in, maybe we can set up a rating system for handling/quality/ride comfort like 0-10 rating. that would be awesome. but i'm just a dreamer..
great thread, yea as people send pics in (hopefully mostly side shots) you can add the pics under each setup? also, a ballpark pricing for each would be sweet. this is all for side by side comparisons, which most ppl probly wanna see, myself included. the more reviews we get in, maybe we can set up a rating system for handling/quality/ride comfort like 0-10 rating. that would be awesome. but I'm just a dreamer..
But you're not the only one.. Lol
EDIT: Prices posted
Cobalt Nation
Brand new pic
Stance GR+ fully lowered but with lockout rings still in the front and only one taken out in the rears. Ive AutoX'd once with this setup and didnt notice anything bad but I also have some Powell Raceshop goodies helping out. As far as going low These take the cake
