Yyz + konis vs coilovers for 500-600whp
Has anyone gone from YYZ springs with koni strut inserts and koni rear shocks(my current setup), to BC coil overs?
Wanting to know if it would be worth the swap for:
1.) Lower stance(just enough to eliminate wheel gap)
2.) Stiffen the rear to prevent any squatting on hard acceleration
I haven't heard of anyone at this power level with a setup like this on yyzs + konis. While I have the upmost confidence in this setup, I'm trying to gather info and experience to determine what would be best for me.
I plan on making the jump to light speed with my batmowheel s259et, shooting for 500-600whp(depending on tires/fuel) and want to have a competent setup to help putting traction down + maintaining confidence in the control and handling of my cobalt at that power level in the street.
Current suspension/drivetrain mods:
Yyz v2
Koni strut inserts
Koni rear shocks
Rotated front/rear trans
mounts(powell)
Trailing CABs
Moog endlinks (may upgrade to powergrid)
4.45 trans
Gmpp clutch kit
****going to get regardless: hardcore/xxx rear sway bar****
Important notes:
-this is strictly a dd for the time being
-street driven only
Basically, would it be worth swapping to coil overs at that power level.
Thanks
Yyz v2
Koni strut inserts
Koni rear shocks
mounts(powell)
Trailing CABs
4.45 trans
Gmpp clutch kit
Important notes:
-street driven only
Thanks
as for the suspension setup, ive always wondered this.
Infra has Pedders XA with R888 on his redline @ 550+ whp https://www.cobaltss.net/forums/whee...review-313928/
maybe powell can chime in on this one.
i think the tire is going to be the other sticking point.
hey has this already lol, its guna be a clutch job sometime in the future though.
Infas had great success with his coilovers and r888s and that thread was very informative, so that's why I was wondering about staying with my yyzs.
As far as the clutch, I know this is asking for a lot but this is a dd so if it starts slipping at a certain powel level we'll just turn it down until it gets replaced ect Again, this isn't going to the track anytime soon.
I sort of went with coilovers. Just due to powell being a auto x guru. I haven't read much on what he knows but I know I was supposed to run the yyz with v1 springs. Yet they are like unicorns. So next best thing. BC coilovers. My buddies and I have had a lot.of track time with the coils. Came out ok.
12.6 on a stock turbo lnf with exhaust,intake and tune. Drag radials.
So I am doing the Same. Since I'm playing with them. I went softer in front. Stiffer in back. Small reverse rake going on but seems to work.
Currently im.going for 550 to the wheels so come spring I'll let u know how the suspension reacts.
Well I don't think axle bind is much of an issue from what I've heard on a conservative drop, just to eliminate wheel gap. I could be wrong but it's more of a slammed issue from what I've heard.
I know the yyz and konis shine through the auto x/ road racing ect, just wondering if the lower center of gravity and overall adjustability of coilovers is worth it - for STRAIGHT traction during wot pulls ect.
i say go with coilovers just because it will be a stiffer ride and the weight transfer wont be too crazy. if your on 18s axle bind wont be an issue at all. im on 17s an decently low but not making the power you are but ive had the coilovers on for about a year now and no axle bind. def get those R888s lol they are so damn sticky and nice esp for roll racing lol all my friends who are making good power fwd and rwd are running those tires they swear by them
I would say try out what you have first, because you already have them. If you want to switch it up after trying it out then that would be the time. I really have no experience with any YYZ's or Koni's or a combination of the 2, I've only heard good things. As far as a spring/strut setup I would think that would be about the best. I have had great success with my Pedders coilovers on my car coupled with my R888's, and I know that my B&G springs on stock struts would have struggled to put the power down because of all the weight transfer, but yours should be much stiffer. So I say try what you have an make your decision from there.
A 2.5" inner diameter spring with both ends flat is a common coilover spring, and they're available in many different spring rates.
As an example, 2.5" ID 10" long Hyperco springs go up to 800lbs:
Hypercoil 2.5" x 10" Coil-Over Springs
^^^ exactly. Viperoni is right on. And the damping is the issue with any cheap ass coil overs. The shock cant damp that spring rate. But if you dont care about the ride, jack the back up and chain the front down with cables or chains and you will be set for drag racing. Better get a trailer ; it will be a horrible car to drive to the track. Hyperco 500 inch pound springs will be linear, best quality, cost about 80 dollars each. The coil overs will break soon enough but I imagine the trans will beat the shocks to it.
If you want to drive your car and go to the track here are YYZ. For best track performance you still would need to deal with the front etc but I am not sure you will go to the that trouble and like I said, the transmission will blow up soon enough. Drag racing is arguably the most difficult, most expensive mechanically sport known to Cobalts.
But still.
YYZ are rising rate. YYZ SPRING SPECS:
V.1
Blue pc finish, acid washed and media blasted.
Front: .540 wire diameter, nominal 12 inch free length. Variable rate, 138/265 lbs.
Rear: .512 wire diameter, nominal 12 inch free length. Variable rate, 108/250 lbs
V.2 December 2012
SPRING SPECS: v.2:
Blue pc finish, zinc phosphate prewash before powdercoating. Shotpeened before powdercoating and prewash.
FRONT:0.532” wire diameter (High Tensile Chrome Silicon spring wire), nominal 11.625” Free length. Variable rate 138/265#/in
REAR: 0.485” wire diameter (High Tensile Chrome Silicon spring wire), nominal 11.250” free length. Variable rate 105/325#/in
Trim height: compared to v1, drop additional 0.350-0.400”Front and 0.750” Rear
By comparison, OEM FE5 Cobalt SS Turbocharged springs are a constant rate of 158 lbs at the front, and variable rate 120/200 lbs at the rear. All other aftermarket springs (including OEM SS Supercharged, and OEM FE3 springs) on the market have less rate than the OEM FE5 TC springs, which were our benchmark for the YYZ springs.
But still.
V.1
V.2 December 2012
SPRING SPECS: v.2:
