TPS only 80% HPtuners
ok guys i've got HPtuner pro and i took a look at the TPS and when i go WOT the tps only go's 80% and not 100% i've been on this for 3 days and im going crazy any one knows how tune or retune the throttle to go 100% on WOT i've pretty much know how to use the hp tuners but this is a killer any ideas
same here 88% full throttle. Been told its normal I just copied the HPT cfg file for the Cobaltss. Some day I'll look at the calculation they used but I'm pretty sure it's not a logrithmic curve, probably a linear +12 to all readings.
the IDC% is what really pissed me off, the average of 2 pulse-width banks when my car only has one resulting in half of the IDC that i was really running. Its good to either take note or check and recalculate some of the stock PID's they set in there to make sure you're getting full accuracy when logging.
take off the intake going to the throttlebody, turn the car to ON not run. Mash the gas and see that the throttle body is wide open. read the TPS% value on hp tuners and see that its 80 or 88.
proof that you are getting WOT
And the answer is to read our stickies http://www.hptuners.com/forum/showthread.php?t=5573
GM changed the way they interpret throttle position on most late model ETC vehicles so you need to log the ETC Position PID in the scanner rather than TPS(SAE)
-Bill
-Bill
