7163 zfr
#751
Surge on spool. Ya that's the actuator I have
#752
So on zacks 2nd log he hit 48.8lbs/min on 27psi and low timing
#754
Hows the spool? Having 36lbs VE but 45lbs MAF is a bit of a difference but having 45lbs/min on 24psi is really good!! Fully built engine stg3 cams and ported head?
#756
I'm finally buying new phasers so as soon as the weather gets a bit better i can resume logs with my car
#759
So I'm taking my car to ZZp here soon to get it running right and get put on the dyno. I'm really excited to finally see some numbers. I will hopefully post everything when I get back.
#760
I loaded HPT 3.0 tonight and while I was at it I updated my tune and all the other big turbo guys I have tuned ao I can not wait to get going again this season!!
#764
Wow that's low boost I ran 29psi. Are you on the high boost actuator?
Nope. Easy to get and I can send it
#767
Ya it's easy to get. All my big turbo guys need to update to 3.0 so i can send the new tune with my updated tables!
#768
I'm gonna test my 3.0 config soon i believe i have it nailed down if i do im gonna order my parts
#769
Also i know it's not a 71 but I'm tuning a 257 this week!!
#772
So after my visit to ZZP on Tuesday. I got my stage 2 cams in and got it tuned on the dyno. I went with a safe tune because almost all of my internals are still stock. It dynoed at 400/352 on 25 psi with 93 oct.
