0-60 times with trifecta and gms1
Old Nov 18, 2010 | 07:51 PM
cdlumb's Avatar
looking everywhere for info on this, anybody know what the times would be 0-60 and 1/4 mile for a trifecta tune and the gms1? I know stock is 5.4 and 13.9, would the gms1 bring that down to 5.2 and 13.4
Old Nov 18, 2010 | 07:55 PM
Turbalt2010's Avatar
i dont know exact time on this stuff but im sure depending on ur mods the times would varey. a complete stock balt with just a tune will be slower then a balt with a tune and intake.
well atleast i would assume so.
Old Nov 18, 2010 | 07:59 PM
slapbetcommissioner's Avatar
doubt 0-60 would change a whole lot... more power = spinning right into third gear lol. 60ft times out thye window never mind 0-60 lol. theoretically better tires would do the trick. even stock the car pushes those tires to the limits of cohesion in a straight line.
Old Nov 18, 2010 | 08:05 PM
not trying to thread jack at all i have just have a quick question about the tires. what tires would be the best for a 24 psi tune? they prolly gotta be so damn soft lol
Old Nov 18, 2010 | 08:12 PM
drag slicks or radials lol..... in a straight line anyway. GL getting slicks for a 17"rim that will fit in your wheel well though... some people use motorcycle slicks as a solution..
otherwise its a pretty heated discussion on what "street tires" are best for drag racing and so forth as none of them are really made for anything more than well balanced handling/ acceleration.. some DR are street legal but generally make handling suffer allot more due to not having a stiff side wall. you can just go a little wider 235/40 r 18 with a good quality street tire (on the softer side) and get improved acceleration.... sometimes
Old Nov 18, 2010 | 09:04 PM
FatboxSS's Avatar
Will going to a wider tire affect handling in a negative way?
Old Nov 18, 2010 | 09:40 PM
Force's Avatar
A wider tire will almost always result in better handling, but these cars are limited - sizes bigger than 245 will rub.
Old Nov 18, 2010 | 09:46 PM
yeah 245 can rub in most situations. if you got wider than 235 you shoud also get a wider rim factory sstc is 7.5 wide. you should go to an 8 wide rim if you want to go a wider tire. or the tire will pucker reducing the amount of tread actually in contact with the pavement.
better handling is relative as it can be adversly affected by weather/ road surface / temperature... so on and so forth.
basically a wider tire will have atendancy to track into imperfections on the road and more likely to hydro plane on water. but in good conditions they should have more tread on the ground therefore more forward traction (depending on how soft and what tread pattern) and if equally stiff or stiffer side wall than factory cornering should theoretically be better as well when driving agressive.
wider the tire the more steering feel you will generally lose though..
Old Nov 19, 2010 | 10:25 AM
SSlobalt's Avatar
Starting these cars from a roll is useless, anyway. First gear is just too short.
Old Nov 20, 2010 | 10:35 AM
80vetteL82's Avatar
+1 First gear blows in these cars. I can't stand how short it is.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
