12.90 e.t.
what would it take to go 12.90 E.T.'s in our cars with stock tires and a street legal
exhaust? how much would it cost? skip. |
A good tune and practice. Cost - under 500.
street legal is a vague term... pretty sure no performance exhaust we put on will be 'street legal' depending on how strict you wanna get.
more than just a tune ....
Tune - thorough Catless DP Modded Air Box CP Driver MOD |
With a tune, weight reduction, the track we run at, this will be enough. Need practice tho.
-downpipe
-3" exhaust -tuning -intake -PRACTICE |
exhaust does little for these cars. Save the $600.
this was a loaded question. saw a guy at the dragstrip the other day
run a 12.95. talked to him and he said all he had was a catless DP, muffler delete, short ram intake, and a trifecta tune. i was like wow. skip. |
Driver mod, learn how to launch. Your 60 is crucial.
Look at my sig, that'll get you into 12's. Tuning is the most critical however. |
Originally Posted by skip_jones
(Post 4247079)
I say stay away from any of the intakes at the moment. Tune, catles dp, and driver mod will get you there
yeah, I don't have the intake on .... yet. We'll see how it acts
Originally Posted by Jn2
(Post 4247070)
-downpipe
hi cmiller. what kind of slicks you running? did you get your new trifecta tune
worked out? you were having some problems that day. or was it the short ram giving you issues? skip. |
(Post 4247155)
motorcycle slick. crazy.
(Post 4247183)
(Post 4247192)
Ha, its OK. It has been done for a long time.
<<< 12.95@ 116 here.... Tune, Charge Pipes, Catless D/P, and custom Intercooler. On street tires
Originally Posted by jb09ss
(Post 4247341)
Any high speed stability problems? Are you using the stock wheels and tires in the back with the slicks?
Originally Posted by 1badBlueberrySC
(Post 4247351)
Yeah, a good 60 foot plays a big role in getting in a good run. I'm hoping with the supporting mods I have and a good 60 I can try and crack into the 12's when I hit the track thursday. But I will be on street tires so it'll be a little tricky.
Originally Posted by Ryans09SS
(Post 4247389)
(Post 4247389)
(Post 4247361)
Yes stock rears, I am not having any problems with them. There are no load ratings, or speed ratings on slicks they are all made the same. Also there are two compounds in a motorcycle slick, motorcycle compound, and a general use compound which is what I got.
I think you are Term. can be in the mid 11.80's with slicks. You guys need to get a set and go run. Yeah, that is on my to do list... 17's with some nice MT ET Streets.... We'll see though! |
Yeah, I've never used the launch control, I've heard it doesn't work the greatest. Cmiller, I am in the Dayton area in ohio.
At what light do you guys start to slip the clutch?
At what rate of speed do you slip the clutch? At what point do you go WoT? I've noticed that no matter when I go WoT with JUST my Trifecta tune I break the tires loose in 1st. Even if I don't break them loose on the launch, then go WoT, they start to break loose. |
