120k miles on the LNF; what can I do to keep it running for a long time to come?
Old Apr 12, 2015 | 11:03 AM
Getaway_Driver's Avatar
I replaced the spark plugs around 115k miles. I do the oil change every 5k miles or so.
The car isn't giving me any major issues currently--- knock on wood that it never does. It does need the catalytic converter replaced soon enough, though.
I want this car to continue running for years and years, miles and miles, boosts and boosts to come.
What preventative steps should I take now that it's hit 120k miles?
Note: I bought the car used and it didn't have the owner's manual.
Old Apr 12, 2015 | 11:20 AM
Well i would say the normal spark plugs, oil, coolant, etc not much other than the regular maintenance to do remember that everything inside the engine is a wear part so eventually something has to give. The less abuse you give and the best you can take care of it the better. Maybe not going into boost at low rpms could help
Old Apr 12, 2015 | 11:51 AM
06blackbalt's Avatar
Fuel filter
LCA bushings
Ball joints
Strut tops
Tie rod ends
Get the intake valves cleaned up gm has a top engine clean that's real good to use.
I'd replace all the engine an trans mounts also
Old Apr 12, 2015 | 11:55 AM
Superbolt's Avatar
Don't forget about transmission oil. Doesn't matter how good the engine is no transmission no go lol
Old Apr 12, 2015 | 11:56 AM
I dont think you can change the fuel filter in a lnf if i remember correctly. Yeah cleaning the valve would be a good idea
Old Apr 12, 2015 | 03:41 PM
kzak104's Avatar
pretty much keep doing what your doing and put a bigger turbo on it.
like others said clean valves, change fluids, to do the fuel filter you need to drop the tank as the filter is built into the pump.
Old Apr 12, 2015 | 03:46 PM
So you would have to change the actual pump to change the filter huh
Old Apr 12, 2015 | 03:56 PM
ae_xiong's Avatar
Y would u even have to change the fuel filter in the first place? "If it ain't broke, don't fix it"?
Old Apr 12, 2015 | 03:57 PM
Lol i think the lsj had the filter outside the tank and its easy to get to
Old Apr 12, 2015 | 03:58 PM
LTBALTBMX's Avatar
All filters need changing if they're functioning properly.
Old Apr 12, 2015 | 04:06 PM
I guess you've never seen a dirty fuel filter
Old Apr 12, 2015 | 04:52 PM
kzak104's Avatar
in that case why change the oil and filter if its still working, why change anything if its still working?
its called preventative maintenance
Old Apr 12, 2015 | 05:02 PM
Joe09SS's Avatar
I am pretty sure the transmission fluid doesn't need to be changed for the life of the transmission from what I've read from GM
Old Apr 12, 2015 | 05:13 PM
09outlander's Avatar
There''s so much aftermarket parts support for these cars that as long as the body shell doesn't rust out I'll have by Cobalt for a long long time.
Old Apr 12, 2015 | 05:15 PM
Superbolt's Avatar
Lol ok you think that and see what happens
Old Apr 12, 2015 | 05:17 PM
umrdyldo's Avatar
100k is about as long as I would let it go. It makes the shifts smooth again.
Old Apr 12, 2015 | 05:57 PM
kzak104's Avatar
you need to drain out bits of 3rd gear every once in a while
Old Apr 12, 2015 | 08:22 PM
turbocharged717's Avatar
Old Apr 12, 2015 | 11:51 PM
ae_xiong's Avatar
First of all, if u read my post correctly I wasn't talking about the oil change or oil filter. I obviously understand preventative maintenance but when it comes to the actual fuel filter I legitimately don't know why it would need to be replaced if there's no issues with it. That's all I'm saying... N yes, I have not seen a dirty fuel filter before hence why I'm asking.
Old Apr 13, 2015 | 06:08 AM
Builttss's Avatar
You really make no sense ^^
Read your own post
Old Apr 13, 2015 | 08:08 AM
umrdyldo's Avatar
On the LNF its in the fuel tank so no one is going to be replacing it
If you own a car with a serviceable fuel filter, you should be. Hanging it. Usually every 30-50k miles. My LS was disgusting t 50k. Very easy to service too
Old Apr 13, 2015 | 04:27 PM
ae_xiong's Avatar
Read your own post
Maybe u don't understand the difference between oil filter and fuel filter?
Old Apr 13, 2015 | 04:29 PM
ae_xiong's Avatar
Good to know, thanks brotha...
Old Apr 13, 2015 | 05:30 PM
user 72239's Avatar
sell it, buy a Honda
Old Apr 16, 2015 | 11:30 AM
RyBread761's Avatar
Yeah man, something about Chevys and their fuel pumps. The filters always kill the pump in time.
