2 quick questions
Old Nov 23, 2008 | 11:35 PM
LSJinTN's Avatar
2 quick questions
1: how do i use bluetooth in my car? my buddy has an 09 ss and uses bluetooth thru his speakers, but i can't figure out how to do it in my 08...
2: how do i know i have LSD? did it come standard or an option?
Old Nov 23, 2008 | 11:38 PM
NoBalt123's Avatar
I don't know about your first question, but with LSD, it will say on the sticker if you have it. It is a factory option, so its possible you don't have it.
If you can't find your sticker, then go out and burn out while taking a turn. if one wheel spins while burning out, then you dont have LSD
Old Nov 23, 2008 | 11:58 PM
LSJinTN's Avatar
the orig. sticker wasn't on the car
Old Nov 24, 2008 | 12:07 AM
Tomtwtwtw's Avatar
Because it's not available in 08 cars.
Old Nov 24, 2008 | 12:11 AM
LSJinTN's Avatar
well that's just ghey
Old Nov 24, 2008 | 12:13 AM
Zander916's Avatar
As stated... the Bluetooth didn't appear until 09.
For the limited slip... open the trunk. Pull up the carpet in the left corner. (drivers side right by the tail light) Look for G85. If you see it... you have it.
Old Nov 24, 2008 | 12:24 AM
LSJinTN's Avatar
what, it's stamped on it?
on what part?
Old Nov 24, 2008 | 01:04 AM
vandy0419's Avatar
eh...you need to take out that you used to own a RL from your sig. Embarassing to all RL owners that you didn't know it only became available in 09...
The stamping is there is a sticker in the trunk of cars under the carpet with all the RPO codes...
Old Nov 24, 2008 | 08:08 AM
LSJinTN's Avatar
sorry vandy... FRO member all the way
yeah, car has lsd
Old Nov 24, 2008 | 01:30 PM
Tomtwtwtw's Avatar
Option two to see if you have a LSD...turn wheel all the way, put in 1st, mash gas.
If car turns sharp, you have a LSD. If car understeers like a bitch and smokes inside tire, you do not have a LSD.
Old Nov 24, 2008 | 01:32 PM
Scythe_Snake's Avatar
Or check the sticker in the trunk under the mat. It will be a silver sticker on the left side and the code 'G85' will be there.
Old Nov 24, 2008 | 06:45 PM
LSJinTN's Avatar
yeah, already figured it out... thnx
i have it
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
