2008 Cobalt SS Brembo brakes - Min. 17" Wheels
Old 12-27-2008, 11:11 AM
  #101
Force's Avatar
Originally Posted by Koz!
Other than Tirerack, does anyone know of a website that sells wheels that fit the TC without needing spacers? I'm not too wild on any of the designs available so far, I like the Superleggeras, but not enough to spend the money on.
As far as I know, you're not going to find a wheel that fits the SS/TC except the OEM for anything other than a ludicrous price. You're best off buying one of the 17" alloys available that only requires a 3mm spacer. Seriously, the 3mm is practically nothing at all... I've consulted 2 wheel shops and 2 dealerships, all of which said 3mm should pose no problem whatsoever.
This is, of course, unless you're looking for an alternative summer wheel to the OEM... In this case, you're looking at paying a big price irrespective.
Old 12-28-2008, 08:00 PM
  #102
rew
rew's Avatar
Originally Posted by ecotecbreed
I will use 17 SS/Sport wheel with 3mm spacer in front, no spacer in rear
make sure to retorq yours wheels about every week then a washer isnt a perfect and they all wont be the exact same thickness
Originally Posted by 2002z06
Installed my Elbrus I05 17" wheels with Blizzak 215/45R17 LM25 did need the spacers in front will try to give a detailed way of how it went. 1st removed wheel and lubed hub & studs with Bendix ceramic hi temp lube 3 mm spacer 3 mm spacer on hub finished clearance Did tire pressure monitor relearn, torqued wheels to 100 ft lbs drove 40 miles and re torqued again, these tires were great on the highway should be good in snow.
you better take your wheels back off and take off the rotor clips or your wheels will come loose you took all the time to take the pictures and give directions but you still did it wrong lol
Old 12-28-2008, 09:28 PM
  #103
2002z06's Avatar
Did wheel runout no deflection with clips, have driven 500 miles taken fronts off no problems with clips learn how to spell
Old 01-04-2009, 03:30 PM
  #104
2002z06's Avatar
Been 800 miles no loose wheels and if you look at the picture of the hub and spacer the clips center the spacers.
Old 01-11-2009, 01:08 AM
  #105
satellite's Avatar
Did we confirm the 18" SS/SC wheels will not fit (even with some spacers?)...anyone know the offset on those wheels?
Old 01-11-2009, 09:47 AM
  #106
SuperchargedSS's Avatar
There's a few pics around here showing the SC rims "just" clearing, so based off that I would say yes. Anyone in Canada looking for a decent set of affordable rims that will clear without spacers just PM me for details. Fast rims SALSA model, 45 offset fits with 4.5mm of clearance, no spacers. 160$ a rim and they look good. There's lots of rims out there that will fit without spacers.
Old 01-11-2009, 03:36 PM
  #107
Zerort's Avatar
Only the 17's from the N/A SS fit. The 18's from the SC do not. They are not even close. Do a search if you don't believe me.
Old 01-11-2009, 04:15 PM
  #108
satellite's Avatar
I believe you...are we talking like "no way, no how" or like 20mm+ spacers... ?
Old 01-11-2009, 05:22 PM
  #109
Force's Avatar
We're talking scary big spacers
Old 01-11-2009, 07:33 PM
  #110
Sorry my bad. I remember that post, it was a 17" SS
Old 01-12-2009, 08:33 PM
  #111
wynand's Avatar
Please post pics with spaces, and of the wheels on the car. I'd like to see how they look. Thanks
Here's a picture:
Old 01-12-2009, 08:39 PM
  #112
Force's Avatar
See my gallery.
Old 03-05-2009, 01:53 PM
  #113
SSpdDmon's Avatar
Originally Posted by CobaltSSTurbo08TG
I was so happy to spend $2600.00 outfitting my car with winter tires and rims which would fit over my big F'in brakes! dumb engineer, great brake though!
You could have spent just $700 and got some Goodyear UltraGrips mounted to the original wheels like I did and saved yourself $1900.
Old 03-05-2009, 01:57 PM
  #114
SS4ME's Avatar
How much is it to convert?
Old 03-07-2009, 03:08 PM
  #115
Koz!'s Avatar
convert what?
Old 03-11-2009, 04:28 PM
  #116
christmanbob's Avatar
Let me get this straight.
So there are no inexpensive 17 or 18 inch wheels that fit the 2009 TC without spacers?
Old 03-11-2009, 04:42 PM
  #117
Force's Avatar
Check the wheels and tires section. There's some reasonably priced 18s that fit no problem. As far as 17s go, I don't know of any offhand that don't require the 3mm spacer.
Old 03-12-2009, 08:38 AM
  #118
Fast Wheels SALSA model 17's, 45 offset fit great, 5mm of clearance. I have them on now. They actually look good on the white balt
Old 03-12-2009, 09:07 AM
  #119
SS4ME's Avatar
convert what?
How much are they charging for the Brembo calipers and rotors?
Old 03-29-2009, 03:38 PM
  #120
nicval's Avatar
They are listed with a 42 offset on their site not 45
Old 05-30-2009, 12:17 PM
  #121
80vetteL82's Avatar
Thats what I did too. Everything worked great, I mounted them myself. These stock rims arent meant for year round....snow and salt doesnt really destroy them like chrome rims. Just make sure you wash them like once every 1-2 weeks during the winter.
Old 07-05-2009, 04:00 AM
  #122
northvibe's Avatar
Id take those Fast wheels but I cant find them in the US...well searching quickly I couldnt. The sales guy I normally talk to at TR said he had a 17" that would fit for about $150 a rim...but man I'd like it to be cheaper than that... still pissed my ms3 snow steelie set wont fit..
so yes whats the most optimum size for 17"?
17x7.5 offset of 42-45? I want to know that so I can search for other rims..
Old 07-24-2009, 06:56 PM
  #123
wylee's Avatar
Where can I get these in the states?
Old 08-08-2009, 11:27 AM
  #124
Routs's Avatar
So, anyone find any really decently priced wheels to use for winter with the Brembos???
Old 09-03-2009, 07:45 PM
  #125
TMRRedline's Avatar
Personally, Im just going to use a set of 18in wheels from a SC and use spacers if needed for the winter. Its the winter, I dont drive the car hard so using spaces is not an issue for me. And you can find SC wheels cheap
Quick Reply: 2008 Cobalt SS Brembo brakes - Min. 17" Wheels
