93 vs E85 60-100
93 vs E85 60-100
Just made a video to show the difference between 93 and E85.
http://www.youtube.com/watch?v=lEt9F...ature=youtu.be
night and day difference for me(supercharged).... i broke loose at 70mph getting into 3rd for the first time after switching over. although i did go from gms2 to 2.8", 80s, and e85, so there was a lot more of a difference. definitely worth it.
You typically log about 55 to 100 so you can time the actual 60-100 time with you at full throttle the entire time. I get too much tire spin at a 50mph 3rd gear roll to get a good 60-100.
If you look at it your actually slower on the E85 run than the 93.... i timed almost a 7 sec 60-100 on the e using pause/play timer
the reason i started at 50 was i wanted to be at full throtle and at the full 24 psi. by the time i hit 60
you sure about that? i re timed it using a stop watch and got identical times.
Some have ran into fueling issues if you have a ton of mods.
Can also run a 50/50 mix or just about any other mixture of the two.
I'll see what I can do
