AEM UEGO wideband
Yes you will have everything you need. Just have to weld the bung to your downpipe.
That being said you don't really need a wideband O2 gauge as the stock upstream one is wideband. Though there are reasons that you would want a 2nd.
As stated above, you can buy an Aeroforce Interceptor that will read A/F ratio from your FACTORY wideband sensor. It will also allow you to read other inputs from the ECM. It will also allow you to read and clear codes.
You DNt really want to tap into or swap out your stock o2 sensor... My downpipe had a bun already on it so I used it and kept my stock one in place after that just tap Into a power and ground and your done the white and blue wires you DNt need. And that's states on the instructions as well!!! Installed mines few weeks back and love it even brought the matching digital boost gauge, then for my dash pod I'll have a interceptor installed.
does the interceptor read wideband for sure? cause i got the plx dm 100 and it didnt
like instantly plug it in and it will read it?
it does read it. i just put 2 interceptors in about a month ago.
i was looking to do the same thing as you with buying a AEM wideband and then i found out theres a wideband from the factory,so i just bought 2 interceptors. too legit!!
and you can read like 30 things on 1 interceptor. all you do is plug it into your ODB2 port
Get the AEM, it saved me a lot of headache when my Upstream o2 sensor went out in the car... I was getting codes saying the car was too lean, yet my AEM was showing pig rich, and you could tell by the smell and smoke the car was piggy. well when I plugged in my computer the front o2 would show the car as lean, never flagged a code for the sensor being bad, just lean.
-Alex
-Alex
-Alex
-Alex
-Alex
-Alex
The interceptor is definitely cool, and most of the time is totally fine/accurate, but relying on trims to diagnose a fueling or a/f issue isn't wise.
I personally agree with this. A seperate wideband isolated from the on board system is ALWAYS a good idea.
Not if the car doesn't come out of open loop due to issues with the o2..
-Alex
n20saturn
Sep 30, 2015 12:26 AM
