Airbag warning wont turn off
Old Jul 22, 2017 | 02:53 PM
Balento18's Avatar
Arrow Airbag warning wont turn off
Hello guys!
a little backstory: the dealer replaced my ignition switch and when I got the car, the wheel felt a little off and with time, the cable hub broke. purchased one online and when I replaced the hub, everything works fine (switches and horn work) but there is an airbag warning that appears on the info screen. is there a way to test the aribag to see if its damaged?
thank you in advance
Old Jul 27, 2017 | 03:53 PM
cobaltssdude420's Avatar
There was a recall for that issue. I went to the dealer for them to do it and they charged me the diagnostic fee because it wasn't due to the problem which was in the recall. I think they were going to replace the sensor or something and charge me $300 but I said **** that and I just drive with the air bag light on lol. Sometimes it's on sometimes not just like the ****** wheel pressure sensors
Old Jul 27, 2017 | 05:05 PM
zeeky420's Avatar
I had same problem with airbag light and I still do but I found that the wire broke on passenger side seatbelt I would look at that first and the tires sensors I had problems with one of them and I let all the air out of all of then and filled and did the reset on them and i haven't had problem since I did that
