Another day, another issue. Wow...
When accelerating, as the car starts reaching closer to redline (maybe by 5k rpm), it'll start bogging and the CEL will flash for 5 seconds or so.
Hooked up my OBDII code scanner, but didn't get any codes.
I love this car, but at this point I'm starting to lose my cool. I've already thrown somewhere over $1000 since January 2015 in resolving issues.
Anyone have any ideas what it might?
Spark plugs were replaced about 10k miles ago. DP replaced less than 1000 miles ago.
I'll try out the spark plugs. Should I just install them pre-gapped? I gapped them to like .032 or something last time I put some in.
You should only be using stock plugs at stock gap or slightly less.
Originally Posted by Getaway_Driver
I just got back from O'Reilly's with NGK iridium spark plugs. Gapped them to .032.
Is that an issue? I don't know if I will be allowed to return/exchange plugs I've already gapped..
Yes stock plugs. When ur car bogs does it backfire like crazy? Could be injector seals, mine did that but with the misfire when I hit over 20 lbs boost at higher rpms.
O'Reilly didn't have AC Delcos. Just returned the NGKs and figure I'll buy some other ones later today/tomorrow.
What are the OEM plugs called?
I know there's iridium, there's those "professional conventional" or some ****, etc.
Okay, thanks, everyone.
This is why I hope this forum never dies. There are plenty of idiots like me trying to do basic work, and this forum really comes together to help as often as possible.
It's always a good site.
ACDelco 41-108
http://goo.gl/nFe4Vp
Also called
GM 12620540
Ecotec 2.0 LNF 41-108 Spark Plugs 12620540
Also called
GM 12620540
