Anyone know what dash wire is for cluster illumination
I knew I should have saved the wiring diagrams before I lost access, but regardless, does anyone know what wire is used for dash cluster illumination? (or any other wire that goes hot when headlights switch on would work too)
i kno illumination wire on my Eclipse head unit is orange
BCM X4-F3 (heated seats..not used)
BCM X4-F2 (boost gage) BCM X4-B2 (to splice) Gray wire at pin D of TCS switch D of fog light switch B of hazard B of boost gage 8 of I/P cluster |
Originally Posted by R4race
(Post 3961022)
BCM X4-F2 (boost gage) BCM X4-B2 (to splice) Gray wire at pin D of TCS switch D of fog light switch B of hazard B of boost gage 8 of I/P cluster So I'd like to use my TCS switch or fog lamp switch because it is closer.. and would switch with my lights. Is that a good idea? |
Originally Posted by krispy
(Post 3945036)
Originally Posted by Maven
(Post 3961649)
Go you need a wire thats hot with the headlights on or a wire thats hot when the dash lights are on? two seperate things.
FYI the info i listed is the dimming circuit
(Post 3968863)
