Anyone know what dash wire is for cluster illumination
I knew I should have saved the wiring diagrams before I lost access, but regardless, does anyone know what wire is used for dash cluster illumination? (or any other wire that goes hot when headlights switch on would work too)
BCM X4-F3 (heated seats..not used)
BCM X4-F2 (boost gage)
BCM X4-B2 (to splice)
Gray wire at pin
D of TCS switch
D of fog light switch
B of hazard
B of boost gage
8 of I/P cluster
Gray wire at pin
D of TCS switch
B of hazard
B of boost gage
8 of I/P cluster
So I'd like to use my TCS switch or fog lamp switch because it is closer.. and would switch with my lights. Is that a good idea?
Trying to wire a foot well light in, want it to go on when dark, when it goes dark both headlights and dash lights go on, so I figure either would work. Was also contemplating wiring it also with rear mirror lights, but that would require some transistors.
