BCM Reader?
Old Dec 15, 2012 | 02:48 PM
Sox-Fan's Avatar
Got Brakes?
BCM Reader?
My Cruise Control stopped working the other day and I'm trying to figure out why. There are no codes in the Engine Control Module, which would lead me to guess that it's the BCM that's complaining. Other than taking it to a GM dealer is there a way for me to find out what the issue is that's preventing the cruise from setting?
Old Dec 15, 2012 | 02:50 PM
SSlobalt's Avatar
Isn't this the infamous brake lamp switch issue?
Edit: or is it the "clutch disengaged" switch? I can't remember which. Go around back of your car and make sure the brake lights aren't on. If they are not, check that clutch pedal switch.
Old Dec 15, 2012 | 02:52 PM
07SSYellow's Avatar
Resident Post Whore/Troll
either that or its a fuse
Old Dec 15, 2012 | 03:00 PM
Sox-Fan's Avatar
Got Brakes?
Brake lights work properly, first thing I checked because I did the LED 3rd brakelight swap a few weeks back.
I can't find a blown fuse and pulling the clutch up with my toe doesn't do anything. The switch could be bad for sure though. How would I test it? I don't want to buy and put on parts that I don't need.
Old Dec 15, 2012 | 03:04 PM
slapbetcommissioner's Avatar
The led break lamps will do the same thing if you don't have a resistor hooked up to them. Put your stocks back in and see if it fixes the issue
Old Dec 15, 2012 | 03:16 PM
Sox-Fan's Avatar
Got Brakes?
It has a resistor though. Cruise worked fine for a month with the LED 3rd brake light on the car. Was driving the other day with it on and it just kicked out. Hit resume and it set for a mile or two then kicked back out. Now it won't even set.
Now, this was the day I got new tires and went from the factory tires to 235/40/18 Maybe the V.S.S. is all upset. Probably not for a change like that though as the tire circumference change is minisule. Probably coincidence.
I still need to step on the clutch to start the car so I don't know if the clutch switch is the issue.
Old Dec 15, 2012 | 05:17 PM
TommyP's Avatar
AWD > FWD
Not due to the tire change. If it was the brake switch your brake lights should kick on when it does it. Usually when that happened with the clutch switch it wss due to people resting their foot on the clutch. Make surr you arent doing that. Im gonna assume you've checked the fuse if there is one. Maybe the cruise switch on the steering wheel is just going bad? Only way to read a bcm code if you were to have one is with a tech2.
Old Dec 15, 2012 | 05:20 PM
094doorSS/TC's Avatar
I'm on my 3rd clutch switch, none of them did anything to the cruise control. When they go bad your clutch will slip when shifting and the car will not start from time to time, unless you pump the clutch pedal and start the car at the same time. It takes a long time for it to set the MIL.
Old Dec 15, 2012 | 06:01 PM
Omnigear's Avatar
Check voltage/ohms/amps
Old Dec 15, 2012 | 11:55 PM
Sox-Fan's Avatar
Got Brakes?
It's not the brake lights. Checked that several times.
Don't ride the clutch. I owned and drove tractor trailers for over a million miles and never replaced a single clutch. I know how to stay off the clutch
Didn't see any blown fuses but I'll take another check. Only checked them once.
I'd check resistance if I knew what amount to check for and where to check it.
In the end I think I'm going to have to pay the dealer to give it a looking at with a tech 2. Not a fan, but i guess it is what it is.
I appreciate all the suggestions and answers. Open to more if you've got them.
Old Dec 16, 2012 | 12:05 AM
Omnigear's Avatar
Uti have a tech2
If u kno a friend there
Old Dec 16, 2012 | 06:29 AM
SSlobalt's Avatar
Originally Posted by Omnigear
Uti have a tech2
Urinary Tract Infection?
Old Dec 16, 2012 | 11:08 AM
K-Train04RL's Avatar
On my redline my switch actually stopped making a connection and replaced that. Working fine 5 years later
Old Dec 16, 2012 | 11:09 AM
Sox-Fan's Avatar
Got Brakes?
Which switch?
GaryGibblez
Jan 14, 2020 10:35 AM
ricklovin93
Aug 27, 2016 06:35 PM
reybalt
Sep 27, 2015 07:57 PM
enduro
North East
Sep 22, 2015 10:01 AM
BettyBlue2.2
Sep 10, 2015 08:49 PM
