bent axle hit a curb *********
Old May 15, 2016 | 01:38 PM
mikeluis92's Avatar
alright guys i was driving around 30 mph i almost passed where i had to turn, i just hit a curb around 20 - 25 mph my rear axle was already bent bt it made it worse now my wheel/ rim is from top to bottom bent inward its noticiable, and so is the front but the front isnt as bad, i took it to an alignment shop, they told me the front is fine they re-aligned it, but my rear axle beam has a bend in it,
question
Could this have caused engine damage?
I took pictures the tie rod isnt broken its fine,
the car is driveable, goes into all gears, it did say low coolant had to refill coolant, had loss of coolant after the incident....
Could i just bend my axle best as possible or should i just invest the 200 bcks and get the rear axle beam?
Any insight or help would be greatly appreciated as i love my car and am distraught after this turn of events,
is this even fixable? am i screwed and should i just sell the car? i dont want to.
Thanks
Old May 15, 2016 | 01:45 PM
Just get a new beam
Old May 15, 2016 | 01:57 PM
post pictures
Old May 15, 2016 | 02:21 PM
mikeluis92's Avatar
Old May 15, 2016 | 02:22 PM
mikeluis92's Avatar
see to the right where the bend is at the rear axle beam is bent horribly =[ i m saddend by this tragedy i hope i can fix it. and
look at the tires, my tires were being eaten within 1 month BEFORE this occured my rear axle was already bad. and the front isnt as bad bt it is bent on the left side.
hoping this is fixable.....
Old May 15, 2016 | 02:23 PM
you could try to find a frame shop near you and ask their opinion, but if they cant do anything about it, you need a rear frame that came with rear disc brakes
Old May 15, 2016 | 02:25 PM
mikeluis92's Avatar
currently trying to get this
http://www.ebay.com/itm/251988601323?_trksid=p2055359.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 15, 2016 | 02:28 PM
mikeluis92's Avatar
**** i wish i could go back change this i regret tryna make that turn paying the ultimate damn price...... ****
Old May 15, 2016 | 02:36 PM
mikeluis92's Avatar
the front you can see how it is inclined =[
Old May 15, 2016 | 02:37 PM
mikeluis92's Avatar
in my garage before this tragedy......
Old May 15, 2016 | 02:38 PM
try junkyards, they will be cheaper than ebay
Old May 15, 2016 | 02:41 PM
That not that bad of a price but expect more for the shipping
Old May 15, 2016 | 03:56 PM
mikeluis92's Avatar
its not bad of a price, the junkyards in miami dont have any cobalts i looked all around for it. unless i get one from a regular cobalt but i dont want to downgrade my suspension. even tho this is from the supercharged cobalt, anyways
i just did a pull like full punch it pedal to the metal, in my 3rd gear boost isnt hitting how before? its feels very sluggish, how could this be? is my transmission damaged now? and also a back fire which did not occur before it did backfire coupple times after i did the pull... am i looking at engine damage too , ? maybe my transmission?
mikeluis92's Avatar
im going to change out the rear axle beam thats suspension not a problem i just hoping i did not hurt the engine from a curb hit..... what took the most impact was the wheels to suspension...@ 15 - 20 mph
Old May 15, 2016 | 03:57 PM
mikeluis92's Avatar
how do i fix that front wheel??
Old May 15, 2016 | 04:09 PM
Take the wheel off and see whats messed up
Old May 15, 2016 | 05:21 PM
mikeluis92's Avatar
i need to take off the wheel, how would i see whats messed up i checked the tie rod and its fine, im not sure what would be messed up
i have a buddy come by check it out
Old May 15, 2016 | 05:55 PM
That seller is in Florida maybe you can save on shipping
Old May 15, 2016 | 08:36 PM
Xmetalhead2003X's Avatar
Dibs on part out.
Old May 15, 2016 | 09:22 PM
Sl0wbaltSS's Avatar
Camber yeah!
Old May 15, 2016 | 10:18 PM
cluelessk's Avatar
Sounds like you need a mechanic
Old May 25, 2016 | 06:08 PM
mikeluis92's Avatar
Fixed new rear axle beam all 4 new rims
bigdogstokes16
Mar 29, 2016 01:52 PM
tomj77
Mar 20, 2016 11:45 AM
KINGMAROSS
Mar 7, 2016 01:47 PM
Slick_Nick
Feb 25, 2016 04:33 PM
