Bnr k04-gt28
Old Mar 3, 2011 | 10:49 AM
  #1101
BYT*SS*TURBO's Avatar
Like I told you, if the O2 was really bad, the MAF will be off and it will knock when that happens. Send a log over already :p
Old Mar 3, 2011 | 10:59 AM
  #1102
FF_ace's Avatar
Originally Posted by drewbroo
My 60-100 times are 4.7 with the E47 mix at higher elevation Well in the coupe.
im running the same numbers as you here in phx
Old Mar 3, 2011 | 11:06 AM
  #1103
jabbott's Avatar
Originally Posted by cubaniche
The potential is there. Ive had a small taste of what it can do but until I figure out what the hell is causing my phantom KR I cant tune any further. It only happens when I accel and the engine torques. Something is tapping somewhere and Im still trying to figure out what it is.
Have you tried performance motor and trans mounts? If something is hitting when the engine torques it should stop it from happening.
Old Mar 3, 2011 | 11:20 AM
  #1104
drewbroo's Avatar
I need to datalog in phoenix sometime
Old Mar 3, 2011 | 11:39 AM
  #1105
FF_ace's Avatar
those times were on a slipping cutch idk what my times are now with the spec 3+ because my timing chain if off still
Old Mar 3, 2011 | 11:58 AM
  #1106
drewbroo's Avatar
I kinda miss my coupe a lil bit.... shes still in for paint.
Old Mar 3, 2011 | 01:49 PM
  #1107
cubaniche's Avatar
I will. As soon as Im home from work tonight
Old Mar 3, 2011 | 09:44 PM
  #1108
T-Man's Avatar
Not bad at all Drew. I'm sure the sedan will be just as quick, if not quicker.
So far, Ive been under the car twice after the install. Once to adjust the WG and the second to recheck and tighten all the bolts just incase there was a small leak. Then I did a boost leak test and found and fixed a leak. Then, a friend fabbed up a bracket for the CP because it did not line up with its mounting screw on the IM to keep it from flexing. I thought at first it would be okay but found that under load the cp was tapping the fuel line, hence the bracket to keep it in place. Then I adjusted the intake cause I found that it was contacting the fender well, and although it wasnt causing issues before I wanted to eliminate all possibilities, so, I put a large piece of foam padding under the intake so it would not rub the fender well anymore. Then....lol...I took the intake mani off to gain access to the KR sensors to adjust then to the 9 o'clock position like others have said to 'de-sensitize' them. The very last thing Ive done is replace the o2 with a new one because I figured maybe that was going bad and skewing the readings and actually causing me to run lean. It was a good idea because it looked shot when I took it out. After aaaaaaaall this, I still have the KR on throttle tip-in though not as severe after I replaced the o2.
Now you guys know all my business lol
I havent heard from any of the other 2860 guys.
Which cylinder is the KR occurring in? Happen when initially going WOT, take off from a light etc.? There's a few of us that get all kinds of random KR on cylinder 4, for no reason, when taking off from a stop (normally). Best of luck man! I'm sure BYT will take care of you.
Old Mar 3, 2011 | 09:54 PM
  #1109
Turbo'dSS's Avatar
Just got my core that i bought for $150 off of a Sky! hell of a good deal i think, it doesnt even have the crack on the divider in the exhaust side!
Old Mar 3, 2011 | 10:14 PM
  #1110
09BlueBaltSS's Avatar
Maybe the car is telling you that it really wants the 2871
Old Mar 3, 2011 | 10:39 PM
  #1111
cubaniche's Avatar
Its only on initial throttle tip-in. More in first from a stop but it registers in all cylinders lol Nick is taking care of me for sure! Thanks to his suggestions Ive found some issues that needed adressing
LOL
Hell, it could be one of the lines I had to modify vibbing against the block for all I know! Short of putting a camera down there while I drive to see if its happening...I may never know haha
Its cool. Ill keep troubleshooting till I get it resolved
Old Mar 4, 2011 | 06:22 AM
  #1112
pbass's Avatar
First, gotta get the DP "gasket" thing fixed (this is the hardest part and I don't know how long it'll take).
Also need the elbows beaded (get Dejon to do it, and get them to re-angle coldside IAT by building up for a new screw hole and drilling/threading it).
Old Mar 11, 2011 | 11:51 AM
  #1113
cubaniche's Avatar
Figured it was time to revive this thread
Tuning is going well now that we've got some issues sorted out. Nick BYT has me on some cool new changes he's made to his tables and first gear is great now and everything feels nice and smooth
We just started working on adding power at WOT now and will be trying my first power revision tonight
Old Mar 11, 2011 | 12:59 PM
  #1114
iboost's Avatar
Glad to hear. My 2871 is heading my ways now. I can't wait to get it on. I'ma get my car dyno'd with the mods I have now and after with this turbo on. I wanna see the difference
Old Mar 11, 2011 | 01:06 PM
  #1115
beast10007's Avatar
thank you i want to know the difference to
Old Mar 11, 2011 | 01:50 PM
  #1116
cubaniche's Avatar
Awesome man! Glad to hear it. Lookig forward to the results
Old Mar 11, 2011 | 02:06 PM
  #1117
pbass's Avatar
What were those issues? (Aside from the WG rod adjustment and boost leak.)
Old Mar 11, 2011 | 03:21 PM
  #1118
cubaniche's Avatar
Its probably just isolated to my engine. Same as I mentioned before, the weird kr at light throttle from a stop. During cruise and wot was fine. It may be related somehow to the E blend since Vince at TF had the same weird issue. Anyways, thanks to Nick, its good now
Old Mar 11, 2011 | 03:49 PM
  #1119
turbo_chevy_cobalt's Avatar
updated on my 2871 we are at 100% watsegate. 26-28 psi 50/50 91/e85 and it feels great.
Old Mar 11, 2011 | 04:06 PM
  #1120
drewbroo's Avatar
I want a ride now
Old Mar 11, 2011 | 04:07 PM
  #1121
I want a ride now
be up there tomorrow and at sir.
Old Mar 11, 2011 | 04:12 PM
  #1122
drewbroo's Avatar
I totally forgot night races start tomorrow. Count me in. I will rally up the troops
Old Mar 11, 2011 | 07:11 PM
  #1123
iboost's Avatar
sounds like sex... I can't wait to do mines
Old Mar 11, 2011 | 07:23 PM
  #1124
cubaniche's Avatar
Sweet! Sounds great man
Old Mar 15, 2011 | 04:15 PM
  #1125
cubaniche's Avatar
Anyone have a chance to dyno yet?
