Boost HELP
Boost HELP
So I have a 2009 turbocharged Cobalt SS and I have this problem where is sometimes when I start it up it doesn't give me the right boost pressure. For example when this case scenario happens it will idle in -20 like it should but no matter how much gas I give it it only gets up to 5 PSI in boost, its tuned so it should be getting 22 pis boost. Other times that works perfectly fine and runs as it should but other times it will do that problem and it all depends on if it starts up correctly or not it never changes once the car has decided if the case scenario will happen or not on Startup. I'm thinking it's the bypass valve getting stuck on carbon buildup or something but I'm not completely sure and there's no leaks in the tubes either. What could be the problem?
Well first let me say I’m not all to familiar with these cars as I’ve only had mine for a few months but does your message board in your car (under your rpm gauge) say: Engine power reduced? If it’s tuned the ‘learn down mode’ has to be disabled
have you done a boost leak test? properly? If you have a boost leak, ur ecu will see that the amount of air the maf sees coming in is not making it to the engine, so it will throw a maf code, or pending code that may not show up for a while, will make ur car run really rich and wont let it boost past 5 psi, that's exactly how it works. so, make sure u have properly checked with a tester, and check for codes, even if engine light is not on.
The only reason i dont think its that is because its very situational, some days whn i start it ill have to restart it so many times till it wrks right amd other days its first start and its fine. Thats what makes me think the little valve or turbo bypass valve may have corrosion that may be stopping it from opening and closing properly, keeping it open sometimes letting the boost out there for creating only 5psi boost
