Brakes Scary when WET !!!
Hello.
I have a 09 SS Turbo with the Brembo's on front. I find that when it's raining and or wet the brakes are scary ! I'm not a timid driver, but when I first step on the brakes in the rain there's no immediate response. It's like I have to dry the rotors with the pads for a second or two before they start to work. So now I'm somewhat ready for it.
I'm wondering if others have experienced this ?
If it's a common thing on these cars ?
And what the problem might be ?
I've changed the front pads that were metallic and quite glazed looking with a new set of ceramics. Braking seems better already, but haven't had any rain yet to test it.
Thanks for any help.
Jeff
Jeff
Slotted and drilled almost entirely fix that issue. Almost All "big break" kits on vented undrilled rotors do this due to water not being a me to escape from under the pad quick enough. Friction causes water to expand causing the pad to sort of hiver over the rotor for a second until the water boils off. Drilled and slotted give the expanding liquid a path to escape.
Changing pads shouldn't make any difference (and helpfull difference) in regard to this.
the first time I thought I was going to **** myself.....
now I just hate the rain but I know a double press will generally do the trick when wet....
I try to stay away from drilled or slotted to many instances of rotor cracking or breaking....
simple fix, remember that in the rain or get a different car if the brakes bug you that much....
Pressing harder makes it worse
The double press is what works best. Or waiting a second for the brakes to catch. Which feels like a century when you suddenly have to stop.
Is this something that only brembo guys are experiencing, because ive never experienced this with LSJ brakes? I do know that the pedal is very mushy on the stock brakes but SS brake lines on all 6 lines solved that problem immediately.
All cars with large disc brakes have this issue to some extent. Just something you get used to and never give any second thought after that.
Or this.
