can somebody explain this
I just got 08 tc black cobalt about 2 months ago and I just learned that the battery is in the trunk.Why did they do this?To help with the front weight bias? And yet the terminals for jump starts are under the hood?
And the battery is away from all the heat in the engine bay.
Its a very smart design.
for real tho... with the battery in the trunk, it sees less extreme of an enviroment(sp, i've benn drinking...) then in the engine bay, think about it, it ten degrees out, you start the car, go to the store its 200, go in come out, go home. the car sits for 4 hours, then you have to go somewhere , you go out and the engine bay is50, you start up drive off then its 200 again that a lot for anything.
The reason i did not know this is because right now I use my Scion Xb as my daily driver.I have only driven it on weekend when the weather is perfect.I might as well keep the mileage down until I return the leased scion in December to Wells Fargo who I can tell I am going to hate by the end of this.(350 dollars or something like that just went you return the car= extortion fee as far as I am concerned)
I agree to a point. It would be better to have the battery weight in the front. Then again, I don't think it would be that much better for traction. The pros out weigh the cons, no pun intended.
Thweather has been rough around me recently and the car is black so I will try to keep the rain off of it as long as I can(has not been rained on yet).Oly a couple hundred miles on it keep garaged and put fresh coat of meguairs tech wax on it.If the weekend weather is nice will definitely check out the fluid levelsjust have been very busy recently.Trying to learn about the car slowly until december when i drive everydayso different in every way then my scionand from car before that acura rsx.There is big blind spot even with the lower spoiler that I have noticed
