Can you motors in the car
Is there a way to check the timing on a LNf without removing the timing cover*please help thanks
need to pull the valve cover and front cover to look at timing marks.
Yeah I was wondering if there is a way with ought removing the timing cover
no.......you can't see the mark on the crank gear with the cover on. Also, without actually removing the chain and lining the colored links up with the timing marks it will be pretty hard to be exact.
Yeah. There's no real way to check timing on these engines unless you're retiming it.
Even if you have the front cover and cam cover removed, the colored links on the chain won't line up. Eventually they would but it'd take an insnae number of engine revolutions to get there. Basically, if you're not setting a code for camshaft position implausible, the timing is correct. |
