can't launch
Old Nov 29, 2010 | 02:00 AM
JacBlackSS/TC's Avatar
can't launch
i just can not get the hang launching my car
its getting extremely frustrating guess i just need more practice
i have tired
slipping the clutch (still need to work on not holding the clutch in too long)
launch control (horrible)
launching at lower rpm like 2-4k ( still tryna find the sweet spot)
launching with the tune off then turning it back on (this got me my fastest qt. mile time)
but i guess i can practice more over winter and if i can master it on the cold ground then come spring i should be ok i guess
Old Nov 29, 2010 | 08:36 AM
BYT*SS*TURBO's Avatar
Have the Traction off, not in comp mode either. Launch at 2k-2500 RPM and slip the clutch to get moving. Then gradually go WOT to maintain traction but keep speed up. Takes practice to nail it
Old Nov 29, 2010 | 08:42 AM
ctn2mb's Avatar
i have tired
Not having bald tires helps as well
Old Nov 29, 2010 | 08:49 AM
Dart_SI's Avatar
its easy once you get the hang of it. even tho its such a ricer thing to do id practice doing launches at empty stop lights. i think im pretty good at it now.
Old Nov 29, 2010 | 10:19 AM
RoadconeTuning's Avatar
i've never had luck either... 2200 and slipping gets me massive wheel spin and 1800 usually results in bogging to a 2.5 60ft lol... i was at a track recently where i dumped slipped it quick at 3500 try to clean off the tires and the car damn near cutoff... VHT FTW!
Old Nov 29, 2010 | 10:23 AM
Godly's Avatar
Welcome to the world of the Cobalt
I launch at 2k, Tune off, Get to about 30 MPH in 2nd and switch the tune on.
Does pretty good
Old Nov 29, 2010 | 10:39 AM
WSFrazier's Avatar
Get the right tires.
Old Nov 29, 2010 | 11:33 AM
SSlobalt's Avatar
Keep in mind that when you do finally hook, that's when your transmission blows up.
Old Nov 29, 2010 | 01:01 PM
slapbetcommissioner's Avatar
Does pretty good
Or have your tuner write your tune to Mimick this.. Probably a little smoother and one less thing to concentrate on,
Old Nov 29, 2010 | 01:12 PM
bobbyhill31286's Avatar
Originally Posted by ctn3mb
not having bald tires helps as well
this!!!
Old Nov 29, 2010 | 01:19 PM
Godly's Avatar
That would be Vince haha. I just wish they'd figure out how to adjust the stock launch control. It worked perfect when I was stock, but 5k = Fail now
Old Nov 29, 2010 | 02:13 PM
WSFrazier's Avatar
On street tires maybe. Shouldn't be racing on street tires anyhow.
Old Nov 29, 2010 | 02:50 PM
I do have brand new tires now lol although the bald ones help me trap at those super high speeds lol
But can you get the launch control adjusted
yeah i am gonna practice with the low rpm launch to see how it goes i got destroyed by a supercharged rsx from a dig last nite i wanted to drive off a bridge after it was over
Old Nov 29, 2010 | 05:12 PM
RyRidesMotox's Avatar
Dude front wheel drive is just a huge pain to launch. The weight transfers to the back tires which is worthless. Just do the best that you can, you'll catch alot of people in second and third.
Old Nov 29, 2010 | 06:16 PM
WSFrazier's Avatar
This.
But using street tires on 18" wheels is just killing yourself. Makes it exponentially harder. Things can be easily added to prevent weight transfer if he is serious about it.
Until you use a small/light wheel with a full slick, you really won't ever understand.
Old Nov 29, 2010 | 07:55 PM
Originally Posted by WSFrazier
This.
Absolutely correct. But not everyone has the cash to get 2 different wheels and tires for the front just to drag with. Maybe the OP should try the football mod? I have heard that helps alot. I want to give it a shot just to see haha sounds like a an amusing idea.
Old Nov 29, 2010 | 08:02 PM
WSFrazier's Avatar
Footballs/air bags. Chain struts. "Wheelie bar" in rear. That is just some of the things that can prevent weight transfer.
Old Nov 29, 2010 | 09:57 PM
drewbroo's Avatar
Does pretty good
you can just give it 50-70% TQ management in 1st and that will help with wheelspin
RaginChopsuey
Oct 27, 2015 01:27 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
JonyyB
Mar 13, 2013 11:50 PM
b-spot
May 16, 2005 08:44 PM
