Car died the other day, anyone else had this problem?
I've notice d a few times I go outside to the car and hit the key fob to unlock the car and nothing happens. I have to stick the key in the door and manually unlock it then it starts honking until I get in. Well a few days ago I go to get in and same thing the key fob doesn't work, use my keys and the horn doesn't go off this time, go to start the car and it's completely dead, not even a click from the starter or a single dash light came on. Had to call roadside assistance and they eventually got me jumped and I drove it around for about 30-40 minutes and then parked it for the day. Yesterday go to get in it and same thing, key fob doesn't work but the car did honk when I opened the door and it did start. Drove to the Chevy dealership and they can't find anything wrong with the battery or anything else. Any ideas? Could it possibly be my bluetooth on my cell is hitting the car form inside the house and draining the battery? Anybody else have this issue? I only have 1100 miles on it and it did sit on the dealer lot for 9 months, figured the battery had just lost a lot of charge over that time but delaership says it is fine.
No not a thing, I just got it a month ago and have around 1100 miles on it. I've taken it on several 4 hour trips and no problems. Car is bone stock.
Is this car like the Corvettes back in 2005 where they had to park it in reverse or it would drain the battery? I leave it in 1st when I park it.
I think it's the battery personally. The car had sit 2 days and not driven when it was dead and with the key fob it is normally when it sits for more than a day and hasn't been driven very far when it was driven.
IMO either it's the BCM busy doing something at the time, something's wrong with the BCM/fob/receiver (maybe keep the other fob with you and try it too when it happens to eliminate that possibility... I know I've dropped mine a few times), or perhaps the ECM/BCM isn't shutting off on its own and is draining the battery over time.
Does your mileage display when this happens? My battery terminal was loose on the negative side and I couldn't lock the doors right after driving. Manually opened the trunk and pressed it down some more and it was fine again.
I was working on something else today and needed to check the battery connections, and it appears everything's connected just fine in my case at least.
Getaway_Driver
40
Sep 10, 2015 09:11 AM
