Car hard to shift
Old Oct 19, 2011 | 03:07 PM
steven2008ss's Avatar
Car hard to shift
Basically, new trans and everything, i didnt beat on it for first 2000 miles and i rarely go to red line or shift over 4K
Everything has been shifting fine, but today it has been harder to get in to ALL gears...i thought syncros at first but it is every single gear, itll be hard to go in to gear the it will go in like butter
it is going into chevy in the AM, wtf could it be?
Old Oct 19, 2011 | 03:13 PM
mongorat427's Avatar
Linkage probably needs adjusted or the plastic clip is bad
Old Oct 19, 2011 | 03:15 PM
hmmm never thought about that either, i know they are plastic pieces of ****, cause the clutch doesnt slip and grabs amazingly as it did when i got it put in
Old Oct 19, 2011 | 03:52 PM
SSlobalt's Avatar
If it was the clutch, it wouldn't be a "grab" issue. It would be a "doesn't release all the way" issue. That would probably just mean you needed to bleed the CMC/slave.
Old Oct 19, 2011 | 03:56 PM
thats what i was thinking too, maybe they bleed it well enough because you need to bleed the **** out of my clutch
Old Oct 19, 2011 | 03:59 PM
Yea, there is no problem with the releasing BTW.
Old Oct 19, 2011 | 10:00 PM
any other opinions?
Old Oct 19, 2011 | 11:12 PM
09TcSedan's Avatar
im in for suggestions too. a buddy of mine has a SS/TC with a brand new trans and clutch and he has the same problem getting it into gears.
Old Oct 20, 2011 | 12:42 AM
JReal560's Avatar
This exact thing happend to my brothers SS. The Dealer replaced his shifting cables. They told him they were seized. He got the repair done for free because it's covered under warranty.
Old Oct 20, 2011 | 12:43 AM
JReal560's Avatar
O i forgot to say it got fixed and feels as good as new lol
Old Oct 20, 2011 | 08:38 AM
well its at dealership now ill find out
first thing guy says is if its the clutch its not covered, i know its not the clutch and i know its not covered....
its most likely the slave, cause is hasnt really acted up since, maybe some air got into the system -_-
Old Oct 20, 2011 | 06:19 PM
LMFAO GM said my clutch is worn out....hahahahha not.....just trying to get more money out of ******* bastards, i dont blame them, they did do over 5000$ of work for free
there is no slipping, no grab or release problem, i think their mechanics are retarded
Old Oct 20, 2011 | 09:35 PM
SSlobalt's Avatar
Pump the clutch pedal 3 or 4 times, then try to put it in gear. If it goes in more easily, you just need to bleed it.
Old Oct 20, 2011 | 09:45 PM
Iam Broke's Avatar
It has air trapped in the line causing the clutch to drag. Manually bleed it from the top of the clutch housing 3-4 times and repeat in a few days. It takes a while to get all the air out of the slave on these. I had the same issue after a clutch/slave install on my LNF.
Old Oct 20, 2011 | 10:59 PM
Air can get in the system at anytime right
Old Oct 20, 2011 | 11:08 PM
Just to add when I'm stopped and I rev it up it seems like the tachometer goes down pretty slow is that normal
Old Oct 31, 2011 | 12:57 AM
<-- hates reviving an old thread but it happened again tonight.
only does it after sitting in the cold, temperatures have been like 32*
Old Oct 31, 2011 | 01:03 AM
ItalianJoe1's Avatar
Sounds like it could be different than stock fluid? If you have some other type of trans fluid, it will, change the effort required by the synchros to engage. Although I wouldn't expect that to happen at a dealership, that's usually what causes the issues you are seeing.
Old Oct 31, 2011 | 01:17 AM
ive been doing research to, on different forums and sites, even tho they are liek STi's its still manual, people were saying that when the temp drops the oil gets thicker and makes it harder for the gears to move in smoothly. they said wait longer til the car is at opeerating temps
what exactly is good operating temps on a cold start i usually wait for coolant to be like 135*
i should have also added in the very first post that this only happens on a cold start
Old Oct 31, 2011 | 02:13 AM
Frogstofall's Avatar
I get stiff shifts when she's cold too. The coolant temp isn't gonna tell you much in terms of the tranny but driving it around and actually putting load on it will warm up the fluid. For me, after 5-10 mins of actual driving it seems much better and I let my car sit and warm up too.
Old Oct 31, 2011 | 09:18 AM
emiller's Avatar
Coolant temp isn't your trans. You could let it idle til the engine is up to normal operating temp (190-210) and your trans, axles, etc will all still be cold. This is why its not very useful for the people who idle the car til its warm then beat on it still break stuff and tell you how they don't understand because the engine was warmed up.
Old Oct 31, 2011 | 09:36 AM
punksk8ter62's Avatar
This. I let my car warm up to abt 100 in the mornings. Then I drive easy until its around 180.
Old Oct 31, 2011 | 09:53 AM
hmmmmm..i have to tell you guys the amount of force i had to use to get into first gear was a pretty decent amount, and when i turned the car off, it kind of didnt want to go in gear either but once in it was fine
Old Oct 31, 2011 | 12:02 PM
emiller's Avatar
Same here. I don't understand how people are so worried about engine temp and ignore everything else. It's certainly not the only thing in a vehicle with fluid.
Old Oct 31, 2011 | 02:17 PM
So guy at aamco drove the car said its Def not the clutch possibly could be the slave
