catless dowwnpipe
i also have TurboXS catless DP. i never threw a CEL with it on here in MD... i am also trifecta tuned not to have a CEL because of no cat...
i went in the emission center. catless and i had the RFL on as well. the guy took the mirror around the car. plugged in something in my OBD2 and said i passed and i was good to go.
car is to new, dont have to go through that crap for 7 years :P, but by then they might have gotten rid of it all together.
if i did have to go through it i would just throw the stock downpipe on.
im in texas, and i was thinking if they just plug up the obd2, wut if my tune was on and removed the cel for the cat? i dnt have access to a stock downpipe being as i will be turbo swapping, does the stocker bolt up to the zzp exhaust mani i might have to buy one from the classifieds?
If they are just plugging it into the OBD2 and you are tuned to not throw the CEL, you will pass. If they wand your exhaust there is a 90% chance you will fail. If they visually inspect your exhaust you are going to fail. Most places in TX from what I remember don't give two ***** about cats. Just get it inspected if you pass yay if not, see if $$ talks =)
Hey everybody
OP, if you have to go through any type of emissions testing (CARB style sniffer or a general obd2 scan) you will fail with a cat-less downpipe. Even if you turned the 02 code off you will still fail because all that does is prevent your cel from coming on and does nothing to the 02 monitors that have to be completed.
Try to find out if you can register your car in a emissions exempt county
z28addiction
Sep 28, 2015 12:03 AM
