Charge pipe blowing off
Any advice to keep the charge pipes from blowing off?? I have the injens with couplers/t-clamps from siliconeintakes.com...They dont blow off all the time, just once in a while. Any input woult be helpful. Thanks.
if your using worm drive clamps then those are shitty clamps and will blow off if your using tbolt clamps some of those are shitty too and will also blow off..
my hahn pipe on the turbo inlet blew off on me during data logging cus of shitty clamps. just get some seabreeze clamps and tighten them down well and end your headaches for good.
I've been running 24psi on Dejon pipes with WORM clamps for over a year. Never had a blow off.
Properly seat the couplers, and properly tighten the clamps.
If they are blowing off at the intercooler, you may have a motor mount issue creating too much engine movement which is pulling them off....
