coil pack
Old May 29, 2013 | 12:00 PM
rogersj's Avatar
coil pack
hey guys im trying to figure out the misfiring codes i got on my lnf p0300 random cylinder misfire and p0301 cylinder 1 misfire. i was just wondering is it possible that if one coil is gone could it cause a p0300 random cylinder misfire?
Old May 29, 2013 | 12:25 PM
VR09Sedan's Avatar
One way to find out is to swap the coil pack on cylinder one with another and see if the misfire code moves. If it does, swap out the bad coil pack and see if both codes disappear. Check to see if your spark plugs are fouled also.
Old May 29, 2013 | 02:02 PM
rogersj's Avatar
1 & 4 have been switched and now i cant get a code but i still feel a bad misfire. Plugs are new gaped to .030
Done compression test and got 160-170 on all cylinders. Cleaned maf and car ran better
Old May 29, 2013 | 02:50 PM
Kbbalt's Avatar
Check the spark Plug boots, I had a bad one, it caused insane misfires on load.
Old May 29, 2013 | 03:18 PM
mongorat427's Avatar
Check the MAP sensor also
Old May 29, 2013 | 04:17 PM
rogersj's Avatar
Is there a way to check it with a meter
Old Jun 2, 2013 | 10:34 PM
rogersj's Avatar
do all cobalt share the same coil pack?
Old Apr 9, 2014 | 09:04 PM
tomj77's Avatar
Id like to know this, I just put some from a 2.2 I had laying around into my lnf and they work fine, they seem to work a little better than the ones I had on there
Old Apr 10, 2014 | 07:49 AM
rogersj's Avatar
just took off my intake manifold the other day and cleaned my valves. changed my plugs and coils. gonna take her out of storage today and try her out lol
Old Apr 10, 2014 | 05:55 PM
cw383's Avatar
What method did you use for valves, walnut blast or brush? How did they turn out? Would like to know if it performs better too, mines past due
Old Apr 11, 2014 | 11:17 PM
rogersj's Avatar
Walnut shell and dental picks time consuming and messy but well worth it if you have alot of build up. Car runs 10x better lol
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
717ssbalt
Oct 2, 2015 04:01 PM
OrangeCoba
Oct 1, 2015 10:00 PM
CobaltSS 16
Sep 12, 2015 02:43 PM
Fearedbynone
Sep 4, 2015 10:24 AM
