cold start/funky sound..
Old Jan 17, 2012 | 09:37 PM
09TcSedan's Avatar
so ive had my car in twice now for this cold start noise. they replaced a couple of parts,cam phasors but i forgot the invoice on what they replaced at my work on my desk.
the NOISE is still there on cold starts!!!!! IDK what to do!
a good friend of mine works at the dealership and he hasnt worked on my car but he did take it to lunch and found out the front control arms needed to be replaced (he noticed a slight clunk)and he got them replaced under warranty. so after a week of the dealership having the car,i finally picked it back up yesterday but this morning i go to fire her up and the noise is still there!!!!
so i called my buddy (who works at the dealership) and told him the noise is still there. he said they will replace the timing chain next... WHAT THE EFFFFFFFFF DO I DO? be a picky ass customer or on of 'those' customers??
the noise is more annoying than anything. i dont think it is hurting anything but idk that.
here is the other thread i was talking with a couple others who had the same issue
https://www.cobaltss.net/forums/08-1...art-up-267514/
Old Jan 17, 2012 | 09:46 PM
rogersj's Avatar
if you could get a video maybe we could pin point it better
Old Jan 17, 2012 | 09:52 PM
09TcSedan's Avatar
ok ill try to get to get one tomorrow when i leave work. its the shortest noise ever. all i have read on these cars ive never herd of anyone saying anything about a cold start noise being normal.
Old Jan 17, 2012 | 10:29 PM
Frogstofall's Avatar
Sounds like a quick moving dry grinding noise right? Mine does it every now and then. There is a TSB for it. Check this thread... https://www.cobaltss.net/forums/08-1...art-up-267514/
Edit: just noticed you linked the same thread. Haha. My bad...
Old Jan 18, 2012 | 04:31 PM
09TcSedan's Avatar
i got a video of my car on a cold start today but im just leaving work so when i get home i will upload it. never uploaded a video on the internet before,anyone have any tips?
Old Jan 18, 2012 | 04:40 PM
user 72239's Avatar
I noticed my car makes a wierd noise on startup, but only for 2-3 seconds then its fine.
Old Jan 18, 2012 | 10:38 PM
09TcSedan's Avatar
prolly the same noise mine is making. drives ya nuts
Old Jan 18, 2012 | 10:50 PM
nobody2u's Avatar
Mine makes this like 'rattling' noise for a second on cold starts every now and then, same sorta thing?
Old Jan 19, 2012 | 08:07 AM
user 72239's Avatar
Yeah its a tad bit annoying, but that TSB says only 09-10 SS's are affected and mine is an 08. Is it doing any harm?
Old Jan 19, 2012 | 08:20 AM
09TcSedan's Avatar
from what ive experienced,no. but i am not 100% sure on that. im not mechanic though lol
Old Jan 19, 2012 | 08:37 AM
user 72239's Avatar
huh. interesting. Let us know the outcome of your repair, I dont have a warranty on my car and I dont even want to think what the charge would be to repair it if I didnt.
Old Jan 19, 2012 | 03:44 PM
09TcSedan's Avatar
im waiting for a call back from the dealership to bring my car in for round number 3 to try and fix this cold start noise. its driving me nuts!!!!!!
Old Jan 20, 2012 | 01:20 AM
AndrewSS/TC's Avatar
Mine used to, disabled cat warm up and it stopped.
Old Jan 20, 2012 | 03:58 PM
RomeDiggy's Avatar
I'm going to try this, only does it when it is about 35 or lower out. My 2010 only has 11700 miles. I hope it isn't messing anything up.
Old Jan 20, 2012 | 04:36 PM
cubaniche's Avatar
Look guys, the best that I can come up with in theory about this issue(cause Ive been trying to figure it out after about 10mo of owning the car, it started) is that the chain tensioner is somehow loosing its pressure and allowing slack in the chain to develop while the car sits for more than a few hours. Then when you start it the chain slaps a bit on the chaing guide while the slack is taken out. I believe that is the sound that we are hearing for that first second at startup, the chain slapping the guide cause it was a little slack.
My only issue with this theory is that Ive had my tensioner replaced twice already LOL
Old Jan 20, 2012 | 06:49 PM
09TcSedan's Avatar
lol^^
my buddy who works at the dealer said that if the sound is still there,they will start with replacing the timing chain and tensioner.
of course i have a video and you can hear the noise but now my damn phone wont let me upload the video onto my computer.
Old Jan 20, 2012 | 10:11 PM
xodus's Avatar
^^^^ same for me also.
Old Jan 24, 2012 | 05:29 PM
cubaniche's Avatar
Here you go! Told you the tensioner was the cause. Took mine apart this weekend because my chain guide snapped. I suspected that the tensioner was loosing pressure thus releasing its hold on the chain, allowing it to go slack. Then, once you start the car the chain slack moves to the intake side where it slaps up against the chain guide there. In my case it caused a failure.
The seal in the tensioner was the culprit! It had come apart and was allowing the oil to seep passed. This caused the hydraulic pressure to lessen. Anyways, I replaced the o-ring with a slightly thicker more robust version I found in an o-ring seal kit, metric not standard. Pics!:
Carnage:
Tensioner apart:
Seal broken:
What it looks like almost put back together. See how the seal is supposed to keep the oil IN the tensioner? That whole assembly sits inside right at the edge of the tensioner keeping the oil in so the piston stays snug up against the chain(guide):
After I replaced the seal and installed the new guide and set timing and put all that **** back together...LOL...she hasntONCE done that sound again. And she has sat overnight without issue, whereas before she'd be off for an hour or two and Id get that noise. Just sharing my experience. I have two other tensioners that I took apart and checked, both the same....seal torn. Why does it keep happening to me? I have no freaking idea but I hope this new o-ring holds up. Also, it still could be the chain or some other cause for you guys, but this seems the most likely.
Old Jan 25, 2012 | 08:55 PM
09TcSedan's Avatar
holy **** man! im calling the dealership. i still havent called them yet! ive been searching for a leaking pipe in my house for the last week but i fixed that problem so tomorrow im calling the dealership asap for this,when i had my car in the last time they said if the problem was still there they would move to the timing chain and check alll the parts around that. i hope it dont happen again to you man! thanks for the pictures and stuff!
Old Jan 26, 2012 | 10:25 AM
cubaniche's Avatar
Glad you got the leaky pipe at home fixed! lol
No problem man. Were all here to help eachother out. I hope it doesnt happen again either. So far so good. Why my particular engine is killing the seals on these last three tensioners is beyond me.
Old Jan 26, 2012 | 02:18 PM
09TcSedan's Avatar
yea dude for sureeee. from the leaking pipe problem to the car now. never ends
Old Jan 31, 2012 | 11:59 AM
cobalt mini bullet's Avatar
trying to get ahold of the dealership to get this checked out... its a ******* joke. yet again... history repeats itself
Old Jan 31, 2012 | 12:10 PM
cmiller8006's Avatar
Sounds like the cam actuators.
Old Jan 31, 2012 | 01:57 PM
its coming right from the timing chain area. Either way the motor is under warranty. Just waiting for them to get back to me, an give me a rental
Old Jan 31, 2012 | 03:50 PM
Chevrolet Cust Svc's Avatar
I hope everything goes well, and if I can be of any assistance please be sure to let me know!
Sarah
GM Customer Service
