dealership help
dealership help
Hey guys, my car threw the CEL and i took it in to a nearby dealership. They are telling me its the fuel pressure solenoid and the fuel purge solenoid went bad. Heres my question, they are asking about 700 for the fix, so i went to autozone to see if i can get the parts cheaper and the guy said he doesnt show the car even has those... So is the dealership trying to screw me or is the autozone guy an idiot? and is 6-7 hundred a fair amount to get it them replaced?
Edit. Its an 09 cobalt ss
Sounds to me like Evap system code, if that's the case you can replace the whole system yourself for about $75
And if it's something to do with the High Pressure Fuel System I would bet it's covered under powertrain.
These are Evap codes like I said.
You need to start with replacing the evap purge selenoid on the manifold.
It's really freaking easy. Just go buy the part. You have to undo one connector and one bolt.
Not sure how good you are but it's as easy as a fix as it gets. If that doesn't work then it's the vent valve selenoid by the gas tank. I did a how to on replacing it. Very easy too and I'm a ******* when it comes to cars.
DDMWorks - EVAP Solenoid Testing and Replacement on Ecotec engines - YouTube
Oh and here is another guy with exact codes and his was the purge selenoid on the intake manifold.
https://www.cobaltss.net/forums/08-1...-p0496-255332/
You can probably find it a little cheaper, but I always buy it from dealership parts departments.
GM part number 12608378 $30 at dealership
Here is ebay link
GM 12608378 Vapor Canister Purge Valve, New | eBay
You will be amazed how much better the car will run. Did you see any other symptoms like hard starts after filling with gas?
Here is ebay link
lol at $700 to fix it. They are ripping you off. Technically its considered a Emmissions part so it should be fixed for free under warranty. I think there is an 80k mile 4 year warranty for Emmissions related items, including the catalytic converter.
Edit* There are 3 different limited Emmissions Warrantys.
3 yr/ 50k miles limited emmision warranty
7 yr/ 70k limited emmisions warranty
8 yr/ 80k limited emmisions warranty
Emission Control Systems
Defects and performance for car and light-duty truck emission control systems are covered for the first 2 years or 24,000 miles, whichever comes first. From the first 2 years or 24,000 miles to 3 years or 36,000 miles defects in material or workmanship continue to be covered under the New Vehicle Limited Bumper-to-Bumper Warranty coverage. Specified major components are covered for the first 8 years or 80,000 miles, whichever comes first. Defects and performance for heavy duty truck emission control systems including those found in 6.6L DuramaxŽ Diesel Engines are covered for the first 5 years or 50,000 miles, whichever comes first.
- Refer to your Warranty and Owner Assistance Information booklet for California emission control system warranty details.
hey guys, i didnt want to make a new thread because its basically the same problem... or i thought. i replaced the evap solenoid. for the last two days its been cutting off when i first start it. itll run for a few seconds like its got a giant cam in it and then it just cuts off. as soon as i unplug the MAF it runs completely fine. ive replace the MAF twice today with two brand new MAFs and neither fixed the problem. it still cuts off after a few seconds and is actually even worse now, i cant move the car from my driveway. anybody have any ideas? threw codes p0496,p0451, and p0101
You have a huge vacuum/boost leak. Either it is a true leak from the intercooler/chargepiping, or your new EVAP solenoid is already stuck open. You can test the EVAP solenoid by removing it from the car and trying to blow through it where the tube connects. If you can blow through it, it's bad (stuck open.) Did you hook the tubing back up after you replaced the solenoid? Just asking.
^^ what he said. DOn't keep replacing your maf. Your maf isn't the problem. Make sure you didn't over tighten the solenoid and crack it. Make sure you didn't leave the vacuum line lose. Unplug it and see how the car runs.
Hey guys thanks for the help, it's now throwing 100 and 114 also. Purge solenoid and mad have been replaced and its still acting up. All lines hooked up correctly and not over tightened. Both mafs have been reman so I'm gonna go to Chevy and try and get a brand new one
update. I went to a chevy dealer and got a brand new MAF. car ran completely normal except it wouldnt build boost and still had the check engine on. so i figured the computer was just limiting the car... as soon as i cleared the codes, car ran like total **** again. it idles like a drag car. up to like 2k and then down to like 600... and then off.... anybody have any ideas? should i just take it in?
hey guys, i figured id take some pics and see what you guys thought. and yes i know im missing that protective plate from the bottom of the ic, one side is damaged and it was just hanging there so i took it off. ill post a video of how its acting tomorrow.
edit: i cant figure out how to upload pics so heres the link to my photobucket
http://s1279.beta.photobucket.com/us...t1089/library/
vid coming soon.
vid coming soon.
Betting on a cracked end tank. Those plastic buggers are prone to crack! I remember seeing a thread that sounded almost identical to this one. It was a cracked intercooler end tank. He cannot build any boost. Sounds like a good start to me. OP, jack up the car and take a look. You might end up taking off the front bumper. Check for hairline cracks as well.
hey you said you took off the condenser bar under the intercooler???? Did you fill the hole it left? Its a stupid question I know but I cant see your pics. They are all red x's.
Oh and did you try replacing the other EVAP solenoid located near the gas tank?
