Direct Injection Question
Old Feb 1, 2012 | 02:55 PM
RaymondT's Avatar
Canada Direct Injection Question
So, i know that the black stuff coming out of my exhaust is because of the direct injection and so is the engine tick. I was just wondering why it poofs black? Does that mean its burning too much fuel? And what is the tick, i remember reading something about it but i forget where.
Thanks
Old Feb 1, 2012 | 03:15 PM
chitala383's Avatar
The constant ticking is the injectors firing. R u saying it puffs black at idle?
Old Feb 1, 2012 | 03:22 PM
soundjunky's Avatar
black is unspent gas making it through your exhaust.
black has nothing what so ever to do with direct injection or not.
Old Feb 1, 2012 | 03:37 PM
nobody2u's Avatar
I had a bit of black come out the other day when I started my car, it was very cold out. Anything to be concerned about?
Old Feb 1, 2012 | 04:07 PM
SlowMs3's Avatar
Do the Cobalt SS/tc run rich stock tune? I know the speeds run like high 9- low 10 AFR stock tune
Old Feb 1, 2012 | 04:24 PM
soundjunky's Avatar
rich to a point is conservative - and will avoid some problems...
GMS1 for example is still rich ~ but a bit leaner than stock...
don't be fooled by mis-reading AFR's ~ if the engine doesn't go rich when gunning it ~ then something is wrong... but for constant/steady speeds you won't see that (or your AFR setuip is probably goobered)
Old Feb 1, 2012 | 04:58 PM
Wangspeed's Avatar
I dunno what tune you're looking at, but GMS1 is lean. Stock setup is lean.
Old Feb 1, 2012 | 05:05 PM
soundjunky's Avatar
I digress, especially in this context the terms lean or rich are kinda subjective...
GM will not make a very lean setup...
But it won't be too rich either.
IF it was very lean your AFR (assuming it's working properly) would be sticking VERY close to 14 or numerically higher...
(14 is an ideal/generic number)
Old Feb 1, 2012 | 08:45 PM
Wangspeed's Avatar
Really, and truly, you scare me.
Old Feb 1, 2012 | 09:19 PM
SSlobalt's Avatar
Holy crap, man. 14 is almost stoich. Our cars run around .88 lambda and you're describing .95 lambda.
Old Feb 1, 2012 | 10:47 PM
soundjunky's Avatar
ok guys, did you read the OP's initial post?
I came here just to try to help ~ a part of which is sharing some information I've picked up...
there is nothing about me that should in any way "scare" anyone.
I never said I know everything, and I wasn't attempting to suggest that I'm always correct.
It seems apparent that people who might know more than me have come in, and found fault with my post(s) ~ when in fact the initial question to which I replied was about black smoke on a stock car.
Sorry if I posted in any fashion which would lead anyone to believe that I believe myself to be any kind of know-all, end all.
fair enough?
Old Feb 1, 2012 | 10:58 PM
dakotaspeir's Avatar
#cobalthoes
My car drops to about 12.4 at wot and around 14.6 cruising. I have the poof of black when I get on it a little after babying it for a while. If it was doing it every time I touched it I would be getting worried lol
Old Feb 1, 2012 | 11:55 PM
RaymondT's Avatar
I just got my car and have it parked for the winter. I start it about every week or so. Since there is snow on the ground when i start it i see what comes out of the exhaust on the snow. Its not too bad and it doesn't actually "poof black" (sorry thats what we call it when our diesels roll coal) just theres a bit of black on the snow. is that okay since the fact i start it every week or two?
Old Feb 2, 2012 | 08:47 AM
#cobalthoes
I would say yeah. My streetbike does the same thing after sitting for a while
Old Feb 2, 2012 | 12:03 PM
Stamina's Avatar
I think some of y'all are getting confused on the whole rich AFR thing.
This car sticks to ~14.6-14.7 AFR at idle and many driving conditions. This is considered Stoichimetric, and is neither rich nor lean. That means that when combustion occurs, all of the fuel has reacted with all of the gasoline, and there is nothing left of either to react. Rich means there was too much gasoline compared to air, and there was gasoline left over, and lean means the opposite.
Under wide open throttle, for safety and power, the AFR richen up and will drop to a lower AFR value, depending on the tune or car.
That being said the term "rich" can be confusing, since it's an ambiguous term (being relative).
For instance, 14.7 AFR technically is neither rich or lean from a chemistry standpoint because it is the perfect chemical reaction balance for gasoline, but it would also be way too lean in a WOT circumstance. Conversely going with a lower AFR is considered rich from a chemistry standpoint (because there would be gasoline left over after the reaction with the air), but may be spot-on for WOT use.
Old Feb 2, 2012 | 02:20 PM
soundjunky's Avatar
great post!
Old Feb 2, 2012 | 02:51 PM
CudaJoe's Avatar
Correction: Going wide open throttle, 14.7 AFR is still neutral (niether rich nor lean) BUT it is not the safest to prevent the engine from heating up to quickly and eventually causing detonation before the piston travel is at its max. The car goes rich during WOT to keep the engine cool using the unburnt gas as "meth+water mix" does for meth injection in a sense. Also it pulls built heat from the turbo too.
The reason you cant just make the car too rich vs meth injection is you will end up with a hydrolock event with gas.
Old Feb 2, 2012 | 02:55 PM
SSlobalt's Avatar
fair enough?
Sorry, I think I just misunderstood what you were trying to say.
Old Feb 2, 2012 | 03:32 PM
Stamina's Avatar
Well, the point I was trying to make is that there's the absolute rich or lean, from a chemistry standpoint, and then there's the relative rich or lean, when being compared to a target AFR. It appeared that people were getting confused about that.
Here's an old post of mine from a while back that explains it a bit more, with relation to fuel trims and stuff too:
AFR: Air-Fuel Ratio. This is the ratio of molecules of air to molecules of fuel. At about 14.7, the mixture is said to be stoichiometric ("stoich"), and is the point where all the air molecules will react with all the fuel molecules. If there is more fuel than air (<14.7), then the mixture is said to be "rich". If there is more air than fuel (>14.7), then the mixture is said to be "lean". There are advantages and disadvantages to being rich, stoich, or lean. Typical car engines usually run stoich for normal operation, rich for warm-up and full throttle, and lean for long cruising to save gas. *Note: 14.7 is stoich for gasoline. Other fuels, such as E85, require a different ratio to be stoich due to their different chemical makeup (about 9.76 in the case of E85).
Lambda: This is the Air-Fuel Ratio expressed as a quotient, when stoich is the divisor. For example, if you're running at 13.0 AFR, then that would be about 0.88 (13.0/14.7). Some applications, such as tuning for the LNF, are programmed instead in Lambda.
STFT: Short Term Fuel Trim. This is the amount of fuel that the engine computer adds or subtracts to maintain the desired AFR. It is usually expressed as a positive or negative number representing a percentage. The STFT is updated and tweaked very quickly by the engine computer. Intakes and other factors can cause the Mass AirFlow sensor (MAF) to mis-read the amount of air going past it into the engine. The engine computer also uses STFT to help compensate for this.
LTFT: Long Term Fuel Trim. This is the amount of fuel that the engine computer adds or subtracts over time to maintain the desired AFR.
The engine computer looks at both STFT and LTFT when deciding how much fuel to mix with the air it takes in. It then sees how close it got to what it was wanting and re-adjusts the STFT and later LTFT again. This adjust-feedback-adjust approach the engine computer uses when the engine is in normal operation is called "closed loop".
Old Feb 2, 2012 | 03:35 PM
CudaJoe's Avatar
I know I know, I just wanted to be a douche I always get corrected no matter what even if I proof read something before clicking the post button. I wanted to try it
Old Feb 2, 2012 | 03:38 PM
Stamina's Avatar
Just face it. You're unable to be a douche. lol
Old Feb 2, 2012 | 03:57 PM
soundjunky's Avatar
that is all
Old Feb 6, 2012 | 01:00 AM
damastah's Avatar
i have a constant black smoke coming out of my exhaust at WOT
lol, AFR is high 11s. maybe 12.0 or 12.1.... very rarely tho
trifecta tuned
Old Feb 6, 2012 | 01:55 AM
soundjunky's Avatar
when you initially gun it - it's supposed to richen out ~ but it's also supposed to go back closer to 14 after a spell...
iirc.
Old Feb 6, 2012 | 07:33 AM
mongorat427's Avatar
Thanks
Ticking is the mechanical fuel pump !!!
