Do not get an intake unless you're custom tuning the car!
Old Aug 18, 2010 | 09:13 PM
  #151
SeanEE89's Avatar
Good read!
I have to agree with what previous members posted. Don't be cheap and get an intake without a tune.
Old Aug 18, 2010 | 11:04 PM
  #152
army_greywolf's Avatar
Ok, since I have both a Tech2 and the laptop connected GM Can controller as well as HPT, let me dispel some thought processes for the tune vs untuned vs intake crowd.
First of all, there is no tune I cannot find using tools available to any GM tech, you cannot hide it, you cannot reflash go for a drive and all is well, you cannot swap ECUs you cannot disconnect the battery and short the terminals.
Here is why. First and foremost I can reference the current software against both GM factory release for the car and any updates. Second I can see every ECM flash event through the BCM, because the BCM is flashed to the car I can look up every change in the software. You cannot HIDE a tune, it is not possible to hide the tune simply put by updating the ECM you are changing the software and thus it is recorded to the BCM, a good tech will check to make sure it is stock.
Next HPT cannot log KOEO trip events(OBDII Drive Cycle Events), but the ECM will log this. It is a comparative between drive cycles that some DTCs are dependent on. For instance Catalyst efficiency, HO2S efficiency, even misfires and evap system codes. If you bring your car in and the dealer uses a tech2 your mostly in the clear they cannot see anything except the freeze frame for whatever set code and the history if the code was set more than once. HOWEVER the newer laptop and CANbus can basically watchdog for mods, like intakes. I can tell if you had an intake on it 500 miles ago even if you reflashed your tune.
Basically what I am saying is you are paying to play guys, There isn't much case for aftermarket charge piping, or cat back exhaust, neither mod could be fingered in most warranty situations. GM doesn't have money to assume everything coming into the shop is warranty related. They'll crack down harder because the shop rate for warranty is less per hour AND the warranty labor is shorter than standard.
What comes into my shop is all the stuff warranty doesn't cover. And most of the time it's expensive.
Wang, good thread.
Old Aug 18, 2010 | 11:11 PM
  #153
northvibe's Avatar
Originally Posted by Jrhdpaintball
hey nick i can send you a log if you want to post the screen shot... not sure how too...
directly after installed injen intake fuel trims were -14%
-14? dang. was the hahn generally going +14 or so?
Old Aug 18, 2010 | 11:55 PM
  #154
Wangspeed's Avatar
Thanks Army Greywolf. Most people have no idea how much more cars are becoming computerized. Me? I love it. I run large scale IT projects. I can wrench on cars, but I'm better at gathering data, analyzing it, and improving reliability and efficiency. Well, that's what I do pretty much all day long at work, but now it can apply to cars. Get a data logger, log, and perform post mortem. Collaborate with peers, lather, rinse, and repeat.
I'm not surprised that most techs cannot find tunes. Most aren't familiar with the internal workings of the ECU. Honestly, they don't need to be 99.999% of the time. People have no idea what they're talking about when they say Trifecta has a tune that's undetectable. Maybe to a totally newbie tech. Dump the data, run an md5sum. It's not possible for Trifecta's to match a stock or GMS1 tune. Sounds like the GM tools are catching up.
Old Aug 19, 2010 | 01:15 AM
  #155
steven2008ss's Avatar
OK im not reading all of that but you DO NOT need a tune if you get an intake, yes it'll **** you up if you have the LSJ but because youre a turbo the more free breathing it is the better it runs, ive had one for a while now with the GMS1 and everything is fine
And im not trying to start an arguement but ive been around plenty of ppl where theyve just had intakes and not a tune and everything has been completely fine with there car. Like STI's and Evo's.
I have the Injen MR Technology Intake the MAF is inthe same spot and everything has been fine. Car runs like a ******* beast. Beats Evo's and stock twin turbo supra (not to brag), and all i have is the GMS1 like i said. I guess it depends on how you work your car.
When i had my LSJ i did an intake and completely fucked up my engine but i believe cause it got wet one day and got the MAF dirty since it was down in the fender. Idk not trying t ostart a war cause i really dont want to. lol. just wanted to share my opinion
Last edited by steven2008ss; Aug 19, 2010 at 01:15 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 01:17 AM
  #156
Topinka's Avatar
is it ok to get a cat back exhaust system without a tune on a completely stock car?
Old Aug 19, 2010 | 01:19 AM
  #157
NORTHVIBE SAID: "Saying an intake will blow up this car and is bad for it is miss information as well. My "nonsense" was saying this is a horrible way to go about informing users. Where is wangspeeds facts on intakes blowing up engines? My points are, stock tune knocks like a ****. k&n datalogged by some has kept decent trims, so how is that worse than stock or stage1? Some people dont want or need a custom tune, but telling them they HAVE to? wtf. I see both sides of having a custom tune and not, you guys only see 1 side, having a custom one.
Isnt there dyno's of stage 1 ppl with intakes getting more power? Just because a custom tune net's you more doesnt mean bolt ons are a waste.'
this is back on page 4 if you wanna find it
but he is absolutely right, you actually acquire more power if you have GMS1 installed with an itake you get more power, idk how but ive seen dyno sheets on here, look back in the basic info threads youre bound to find one, i have about 320 HP, and go figure. I guess the guys at GM know how to tune a car
Bro if you have the LSJ you should be fine
if you have LNF get the catback with out cats, MORE air going to the turbo, thats what you need
Last edited by steven2008ss; Aug 19, 2010 at 01:19 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 01:22 AM
  #158
Topinka's Avatar
thats what i thought but my dealer said it would cause problems with some sort of reading because its a "high flow" system. i have an lsj by the way
Old Aug 19, 2010 | 01:23 AM
  #159
THe LSJ is tricky because it is belt driven, any air flow changes you might have to get a tune, cause the car is used to getting a certain amount of air flow. With the LNF, if the car is getting more air its no rejecting it because it wants it.
Old Aug 19, 2010 | 09:03 AM
  #160
kyle1853's Avatar
Wang, good thread.
why can you not swap ecu's may i ask?
Old Aug 19, 2010 | 09:08 AM
  #161
BYT*SS*TURBO's Avatar
Wang, good thread.
Welll, you should check on the HPT forums, because 3 separate sets of people have tested the way we flash it back to stock and all showed it as stock and untouched.
I also had my car serviced for a problem with a cam seal as well as the brakes and some other things that weren't right, and because they knew me and know I work on cars, they checked everything before they touched my car under warranty. They also verified my car was untouched.
So because it made whp on a dyno that means it's ok? Interesting..... Shooting Nitrous into the intake without adding fuel will make power too LOL...
That has absolutely nothing to do with anything we are talking about. A turbo car doesn't reject the air is LOL... If you change the diameter of the pipe, the location of the MAF etc.. you are changing the way the VCM interprets the airflow reading and the will skew the MAF's. This is simple stuff...
Last edited by BYT*SS*TURBO; Aug 19, 2010 at 09:08 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 11:13 AM
  #162
im officially backing out of this one cause i am too old for flame wars on the internet, peace, i do not wanna make people cry and hate me so have a good day everybody, ill leave by saying dont always believe what people tell you
BTW, look here http://www.stealth316.com/misc/obdii_fuel_trim.pdf
ill copy and paste a good part,
"Let's look at some conditions that will set adaptations faults and there causes.
Intake air leaks
Incorrect Fuel Pressure
Injector valve defective or coked
Engine Temperature Sensor defective
EGR valve defective
Secondary air leak
Fuel evaporation control system defective or leaking.
Air Mass Meter defective
Vacuum leaks
Oxygen sensor aging (slow response)
Clogged or damaged catalytic converter
Contaminated fuel
Fuel tank ran empty
Combustion altered by a mechanical failure (Spark plugs, compression, intake/exhaust valves, ...etc.)"
it says nothing about changing intakes....
Last edited by steven2008ss; Aug 19, 2010 at 11:13 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 11:21 AM
  #163
cubaniche's Avatar
Okay, from my understanding tuning for an intake is a global change in the ECU right? From what Ive been explained the MAF tables are global and not tune dependent. So if someone has a dual tune, logs the car and has the tuner tune for the intake, it should affect both tunes correct? Like in my case I have GMS1 and then a Trifecta 23psi selectable tune. So if I was tuned for my intake logging while on the Trifecta tune, it should also affect the GMS1 side of things too?
Old Aug 19, 2010 | 11:34 AM
  #164
Intake air leaks
EGR valve defective
Secondary air leak
Vacuum leaks
Contaminated fuel
Fuel tank ran empty
Another person that doesn't have the facts that pertain to THIS car yet knows it all....
You are posting data from a Dodge Stealth site lol. Then you are saying what can and can't work yet you don't actually know (like the rest of the people arguing) because you aren't logging THIS car with intakes to see the actual changes. Your arguement is based on another site, another car and nothing to do with THIS car. That list doesn't show how the car will go into a limp mode when the MAF change is greater then 20%, OR how this car knocks excessively when the fuel trims are way out of wack.
If you saw how this car reacts with a tuned intake vs a non-tuned you would see what is happening. This car is extremely sensitive when it comes to the MAF tuning, just that alone will make the car clear up it's KR thru the midrange.
I run a combo tune and Vince told me the MAF tuning remains for either tune mode, so does the rev limit change.
Last edited by BYT*SS*TURBO; Aug 19, 2010 at 11:35 AM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 11:41 AM
  #165
cubaniche's Avatar
Thanks BYT for confirming this.
Old Aug 19, 2010 | 11:49 AM
  #166
PrincessTurbo's Avatar
Originally Posted by SSlobalt
What's retarted and a waste of money is throwing expensive aftermarket parts on your car, then not tuning it for them, so that your car actually runs worse than it did before you spent a bunch of money.
What's retarted is putting a part on your car that makes it run unreliably, just so you can hear the sound of a BPV opening.
LOL , its a placebo effect ...
Old Aug 19, 2010 | 12:11 PM
  #167
Terminator2's Avatar
Some of you are way off base here. Let me make this very clear. Most of you have very little if any tuning experience so your arguements are baseless. I see some comparing a Dodge to a Chevy. That is not a valid comparision at all especially given the fact that most Dodge cars and trucks are speed density (SD) tuned. For those who do not know what SD tuned means it means they have no MAF sensor to measure airflow. They base all their fuel calculations ( calculated cylinder airmass) off RPM, load, and MAP. Because there is no MAF sensor to skew you could put a piece of 6" PVC pipe on there with no filter and the car would run just fine. Try that with a MAF tuned car and see what happens.
Old Aug 19, 2010 | 12:29 PM
  #168
^You mean the car seems fine isn't a valid fact? lol
Old Aug 19, 2010 | 12:30 PM
  #169
Jazer's Avatar
Originally Posted by Terminator2
Some of you are way off base here. Let me make this very clear. Most of you have very little if any tuning experience so your areguements are baseless. I see some comparing a Dodge to a Chevy. That is not a valid comparision at all especially given the fact that most Dodge cars and trucks are speed density (SD) tuned. For those who do not know what SD tuned means it means they have no MAF sensor to measure airflow. They base all their fuel calculations ( calculated cylinder airmass) off RPM, load, and MAP. Because there is no MAF sensor to skew you could put a piece of 6" PVC pipe on there with no filter and the car would run just fine. Try that with a MAF tuned car and see what happens.
Exactly.
That's a lot of what I was getting at when I posted.
There is fueling via MAP vs RPM then theres Alpha N which is RPM vs TPS, then theres MAF, etc... I've seen too much mis information in here to even bother with most of it. MAF driven cars are sensitive... this is also why you have to be careful running an atmospheric dump BOV as well.. But that's a whole different topic.
Old Aug 19, 2010 | 01:02 PM
  #170
Originally Posted by northvibe
Okay I had pm'd term2 a while ago and never got a response. My thought was, everyone with data logging abilities, log their car stock, and then install X intake and data log, and we have a thread sticky for us where we can post the environment details (weather etc) and the logs to show what is going on per intake, per location. THEN everyone can see actual logs, from more than 2 people and actually data instead of just what is "said" on the forum.
When? I always respond to my PMs if the site is working properly and I can send and receive them anyway LOL. Right now my email and this site are messing up.
Originally Posted by Jazer
Exactly.
Especially a MAF sensors that are not equipped with a laminar flow straightner in front of them like the LNF cobalts, the 2.2L cobalts and the LS7 corvettes just to name a few. The factory airbox, right down to the factory filter and snorkel are designed to minimize turbulance over the sensor giving the cleanest readings possible. They are act as airflow straightners so if anyone changes anything about the stock airbox it WILL skew the sensor's readings which will mean an A/F that bounces up and down as the WB 02 tries to compensate (The LNFs are constantly in closed loop mode). The problem is the WB can react only so fast to changing 02 readings so by the time it reacts that lean or rich state may have already passed and then it will cause over or undercompensation and many more lean to rich osciallations.
Last edited by Terminator2; Aug 19, 2010 at 02:10 PM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 01:08 PM
  #171
importkiller's Avatar
TERMINATOR2 to the Rescue
Old Aug 19, 2010 | 01:16 PM
  #172
Except he's a day late lol. The fight is dying down now
Old Aug 19, 2010 | 01:19 PM
  #173
northvibe's Avatar
hmmm back when I was msg'ing you more often, it was probably mixed into a message when I asked something or responded. Given this sites history....you never know.
Old Aug 19, 2010 | 02:09 PM
  #174
Sometimes I do not get the messages that are sent LOL. This site crashes a lot.
I hope they come back.
Last edited by Terminator2; Aug 19, 2010 at 02:09 PM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 02:17 PM
  #175
ebristol's Avatar
I agree with this thread 100%.
Originally Posted by PenguinPIE
does this apply to LSJ?
Yes.
I switched from the stock intake to the ZZP 3" and my entire had almost 10% error. Closed loop will fix it under normal driving but not Open loop!
Get re tuned.
