do they make the gmpp clutch anymore?
Old Mar 27, 2018 | 11:46 PM
AG305's Avatar
hey there.
so my clutch is begining to slip and i know im gonna need a new one eventually. the previous owner of the car said he installed a gmpp clutch on it and it has been great so far. im looking to buy another but cant seem to find it anywhere. all i see is lsj stuff and not lnf. he also said i have a 4.05 trans from zzp so im not sure if the type of clutch i gotta buy is supposed to fit that specific trans or the stock one. any links would be greatly appreciated!
im also not against getting a different clutch thats easier to find if i have to. i just love that the gmpp is dirt cheap compared to the others and has been great to me. my plan is going with a ko4r and meth next.
would it be better to get a different clutch for the added power or will a gmpp handle whatever ill get from my new setup?
if the gmpp isnt enough, whats a good recommended clutch thats easy to street and not so much an on off switch?
Old Mar 28, 2018 | 12:44 AM
Sharkey's Avatar
the gmpp clutch was never designed for the lnf, and its always been marketed for the lsj. however, lots of people run them with the lnf and they do seem to work well.
Old Mar 28, 2018 | 08:39 PM
63 Nova SS's Avatar
Looks like crate engine depot is backordered on them.
Old Mar 28, 2018 | 10:07 PM
Dutchman's Avatar
Call up Tom at Crate engine depot and he helped me out last summer when my clutch went
Old Mar 29, 2018 | 02:03 PM
califcarm's Avatar
I put in the GMPP clutch a little over 20K miles ago. Not sure it will handle a K04R +meth. After break in I was able to ramp in up to 24psi by 3000 rpm in 3rd gear and 3500 rpm in 4th gear and not really overpower the clutch if I brought it in smooth by that rpm. But about 3-4K miles ago I had to soften the boost ramp in and have tuned to bring in 3rd gear full boost by 4K rpm and 4th/5th gear boost (all 24psi) by 4500 rpm to keep it from sometimes slipping in cooler weather.
I also reduced the aggressiveness of my spool PID tables for a little more mellow transitional boost when going WOT to keep that from sometimes slipping.
I am only a few bolt-ons with stock turbo and tuned on 93 octane. But runs strong.
So with what you are shooting for, will it hold the power, yes. But you will have to keep peak torque from being too high too early or it will over power the clutch.
But maybe that is just going to keep the trans safer so you don't break something inside of that.
Old Mar 29, 2018 | 04:05 PM
AG305's Avatar
that makes sense yeah. i do like the gmpp though but i think for where im headed its safer to just get a different clutch that can handle the power.
what are some good clutches available nowadays? something thats not so much of an on off switch. i daily the car.
Old Mar 29, 2018 | 04:34 PM
hawkssoccer11's Avatar
depends what your goals are? i run e85 on the GMPP with full bolt ons and a 22psi tune. The GMPP clutch has been in my car now for 4 years or so. its held great and has taken some abuse esp being on e85 during spring/summer/fall here lol
Old Mar 29, 2018 | 08:46 PM
63 Nova SS's Avatar
I run e47 full bolt ons on a KO4+ and it's holding so far. I have probably 15-20 passes on it at the strip with drag radials or slicks using a wot box with 4psi off the line. I'm boost ramped .
Old Mar 29, 2018 | 10:05 PM
AG305's Avatar
my immediate goal is ko4r + meth and eventually a 6758 or 7163. ill probably run the ko4r for awhile though so if the gmpp can handle that ill stick with it. im at 385 tq right now so im not even sure if its slipping because its going bad of if its to much tq. it wasnt slipping before so im gonna guess its just time to replace it.
Old Mar 29, 2018 | 10:11 PM
AG305's Avatar
not bad. i cant see a ko4r and meth being too much different than your setup. i dont really drag race so i think i may be fine with another gmpp but not entirely sure.
Old Mar 30, 2018 | 06:59 AM
63 Nova SS's Avatar
If you boost ramp the tune you will be fine. Will it last as long as a clutch that costs 3 times the money, probably not. But it's a good clutch for the money. A lot of it depends on how you drive.
Old Mar 30, 2018 | 09:47 AM
Not to mention a clutch is cheaper than a transmission and a full face is easier to daily drive than a pucked clutch. It's held up well for me (~80k).
Old Mar 30, 2018 | 10:49 AM
AG305's Avatar
thanks alot for the replies. i think i should be good with another gmpp. its held up great so far with my current power. i dont really launch the car or hit wot full boost under 3k and stuff like that.
so, the gmpp was never actually made for the lnf? am i safe to buy an lsj one then? what about my trans? does the type of trans and gearing affect what clutch i need to get? how can i know exactly what trans i have and stuff? previous owner says he put in an old zzp trans thats not available anymore so im guessing its the 4.05
Old Mar 30, 2018 | 11:51 AM
T-Man's Avatar
If it makes you feel any better, my stock clutch took the abuse of a K04R that I was pushing decently hard and then again with my WR-3(6758 EFR). I'm honestly considering removing my Frankenstein KY clutch for a GMPP.
The best thing you can do is to ensure that when you do the clutch, you replace all of the hydraulics as well. Either a stock LNF clutch or a GMPP clutch will do you just fine, so long as you/your tuner are competent enough to not have boost come in like a sledgehammer. My Dad has an 09 coupe with a K04R on ethanol and a factory LNF clutch that I tuned. He beats the **** out of that car and the clutch doesn't slip with 25-26lbs/20* of timing.
good luck man!
Old Mar 30, 2018 | 02:19 PM
AG305's Avatar
good luck man!
wow thats actually very reassuring! what kinda numbers were you seeing with the ko4r and ethanol? im sure a gmpp is good enough for how i drive.
Old Mar 30, 2018 | 02:39 PM
T-Man's Avatar
No idea on numbers as I never put it on a dyno. I'd estimate around 370whp and 380wtq.
Old Mar 30, 2018 | 05:18 PM
AG305's Avatar
sounds good to me. i have around the same tq right now and the clutch was fine. ill just bite the bullet and stick with a gmpp
Old Apr 3, 2018 | 09:13 AM
people need to look past the "LNF" and "LSJ" **** when it comes to a transmission. they both use the same transmissions just different gear ratios. so yes when it says upgraded LSJ clultch it will still work for the LNF becuase they have the same transmissions.
Old Apr 3, 2018 | 09:39 AM
cw383's Avatar
My GMPP clutch held up great with the 6758. With 7163 it finally met its match. I think the 4.45 gears in my trans really helped save it from slipping up until that level though
Old Apr 3, 2018 | 09:42 AM
AG305's Avatar
good to know thanks!
Old Apr 3, 2018 | 09:46 AM
AG305's Avatar
thats great! i spoke with the previous owner and he said i definitely have a built zzp trans with 4.05 gears in the car so i should be good to go i think.
Old Apr 3, 2018 | 11:16 AM
exninja's Avatar
Yes, the only different are the flywheel dowels. You can use the bic pen trick to line up the pressure plate.
Old Mar 1, 2019 | 08:51 AM
Larrayjayy96's Avatar
Sorry to raise this thread from the grave but does anyone happen to have the best contact number for CED? I ordered the GMPP kit its been about a week ago and I havent gotten any conformation as far as shipping. Thanks in advance..
Old Mar 3, 2019 | 06:57 PM
06cobaltss/ss's Avatar
i use it in my 2010 with full bolt ons and tuned. it slipped when it was cold but my tourqe spike was pretty mean. new tune is turned down a bit. the e47 tune will be more agressive then the 93 so im curious to see if it kills it. if so i will buy another gmpp.
Old Mar 4, 2019 | 04:50 PM
Contact Us
you try calling the number on their website?
