Does the S/C analogue gauge work in the T/C
Old Aug 13, 2018 | 07:28 AM
StevoElSupremo's Avatar
I tossed a supercharged analogue gauge I got from a wrecked car in my T/C yesterday (I have the RPD) wired it up and it works, but doesn't look like it's boosting past 5-8ish psi...but my RPD reads right around 103KPA (15ish psi)
Sooooo...thoughts? I guess it's just not something I thought about before throwing it in or am I missing something here and it should be working just fine? lol
Old Aug 13, 2018 | 01:33 PM
user 72239's Avatar
negative. they are not interchangeable.
Old Aug 13, 2018 | 03:15 PM
Aha thought it was strange...didn't even think to check first I just assumed it'd work....ah well good thing I just two way taped it to the steering cover I guess I'll take it out.
Old Aug 13, 2018 | 03:37 PM
user 72239's Avatar
I dont remember exactly why, but the way the ECU calibrated for the stock ie. 30 psi LNF boost gauge doesn't work when you swap to the LSJ 20 psi. I remember asking if i could swap to the lnf one when I had my first LSJ and everyone told me no. so i bought a prosport. but I like the OEM look of the LNF.
Old Aug 13, 2018 | 04:15 PM
Kolt's Avatar
The way the data is sent from the bcm to the oem gauges doesn't match the calibrated location on the guage face.
If you compare the location of 8psi on the sc guage to the 15 psi location on the tc guage its about the same.
Same with the "zero point" is 180 from peak on the sstc guage but 180 on the ss sc guage is about -7inhg
If im not mistaken the gauges are internally the same but the face is changed, so in theory you should be able to disassemble the gauges and swap the face.
A way to test this is to put your car in key on engine off and see where the "zero point" shows up. If its at about -6 to -8inhg on the sssc gauge (or 180 from the max) you should be good to swap faces.
Only issue is the needle has to be in the correct location when reinstalled or it wont show accurately.
Old Aug 13, 2018 | 05:04 PM
so if they're both internally identical I wonder if I could pull the front of the gauge off pull the needle off turn to ACC so the gauge "zero's" then put the needle back on pointing to zero like you do when you pull the speedo needles off.... I might test this later....or like you said if the font spacing isn't right then as the car thinks it's reading 15psi it will only show 8
I've left the gauge in for now, it's fun to watch it bounce around and I know when it hits 5PSI it's maxed ....for real though I will sort it out...got nothing to lose might as well clown around with it.
Old Aug 13, 2018 | 05:21 PM
Kolt's Avatar
idk about just moving the needle since the guage faces have different spacing on the numbers.
Old Aug 13, 2018 | 06:01 PM
user 72239's Avatar
I should put the LNF one in mine so when I hit 8 psi, it saying 20 and i can be like AWW YEAH 20 PSI bitch in my stock M62
Old Aug 13, 2018 | 06:19 PM
So to my suspicion about the gauge reading 5 when it's 15psi being 10 off I went and checked and it is "zero'ing" at -10, so it is 10 off, so I simply popped the faceplate off (what a bitch to do cleanly!!) pulled the needle off,...ACC let it zero popped the needle back on.
Took keys out and it now zero'd on zero! started the car and it decided to freeze in place and no longer read boost... checked the wiring everything was still great! so I ripped the ******* thing out and threw it in the closet.
Old Aug 13, 2018 | 06:22 PM
Kolt's Avatar
damn, May have jammed the stepper motor pulling it off and pushing it back on. Make sure the needle turns freely by hand, may have also pushed the needle too far down and its rubbing on the faceplate.
Old Aug 13, 2018 | 06:24 PM
Kolt's Avatar
Originally Posted by HGT
Is the 20psi gauge available from Autometer new or was it only made for GM. I like the gauge now that I have the SS red dash
As far as I know the gauges for sssc and sstc where only made for gm. I have tried finding them from autometer directly but no dice
Old Aug 13, 2018 | 06:30 PM
Nah I was very gently about it (I've pulled cluster needles so many times) and when you tap the gauge the needle drops on it's own easily, IDK what happened....maybe pulling the needle on and off a few times did something but blackcatz website shows the same process to swap the faceplates.
well whatever I wasn't going to keep it there regardless reading the wrong pressure, just a bit confused why it stopped working lol
Old Aug 13, 2018 | 06:37 PM
Kolt's Avatar
Damn, that sucks man. Maybe it got pissed you were molesting it.
Old Aug 13, 2018 | 06:43 PM
Who knows, I'll probably just get a proper mechanical gauge and pillar pod in the future.
Old Aug 13, 2018 | 10:34 PM
heeter_33's Avatar
Where did you get the pins to wire it up? Or did you just pull them from the wrecked car too? I have the analogue gauge in my car that I've never actually wired cause I don't know where to find the pins and connector.
Old Aug 14, 2018 | 02:31 AM
Sharkey's Avatar
My original Innovate WB gauge crapped out so I think I am going to go this route so I can use the Power Safe feature with a solenoid to pull back the boost.
i run the innovate scg1 wideband and boost control on my 944. the failsafe feature on it works quite alright pretty decent.
Old Aug 14, 2018 | 10:19 PM
heeter_33's Avatar
The easy wiring is just Power, Ground and dash dimmer.
The supercharged gauges get their data from the PCM Boost Gauge Signal
The turbocharged gauges get it from the ECM Boost Gauge Signal
They are not interchangable.
I know, but where do I get the pin to plug in to receive the ECM boost gauge signal? I phoned the dealership and they would only sell me 100 or something. Just rip some used ones out of a junked car I suppose.
Old Aug 15, 2018 | 07:00 AM
I cut the whole harness from the wrecked car to harvest the pins lol
unforgiven
Dec 9, 2014 10:24 AM
Aleksey
Feb 28, 2013 04:49 AM
scotch89
30
Jan 5, 2013 09:08 PM
Stamina
Aug 25, 2009 11:28 PM
NarutoDF
Mar 9, 2009 01:43 PM
