The dreaded porus block bites again
I am pretty sure this is what I have, raced an RT Challenger last week end several times and had positive results each time but low coolant light showed up next morning and oil level was over full, added more coolant and the next day another low coolant light and oil level even higher, I figured it was a head gasket and that I needed studs but after talking to ZZP and searching on this forum I feel its the porus block, I told ZZP I made 25 psi and they said they have done 53 psi on stock head gasket with no problems. I was considering the LDK engine but had a co-worker say why not try some block sealer, so with nothing to loose that is what I tried today. The jury is still out so won't have any results for a day or two.
Back in the day before all the aftermarket small block Chevys came out we used to fill the block up 1/2 way in order to make it stronger. Ran a little hotter but it would take lots of abuse. Now they build hd blocks from aftermarket companies and you don't have to do it anymore.
Right around 120K, it had 115K on it when I bought it. I was pressure checking it pretty good with the Challenger, Speedo was showing 155 and I think it had 10 more in it. Challenger gave up around 140-145
About the oldest on here-47.
If mine had 115,00 on it, and you had the money, I would probably just go with the long block. They are a really good deal for a sealed engine. I've got more than that just in the block and crank in the nova.
Wish these cars resale was better but as it is you really just go in the hole spending money on them. Try your idea, at this point you have nothing to lose, just make sure it doesn't go through your cooling system or you may be fixing more than the motor.
How did you decide on a cobaltSS? I got one because I wanted something fun that got good gas mileage while I redid stuff on the nova, and now I can't quit messing around with it long enough to finish the nova. Truck only gets 13 mpg and was tired of putting $4 a gallon gas into it when I got the cobalt.
Not much in common with a lot of the guys on here due to where I am in life. Welcome
