Engine light
Old Jun 5, 2010 | 02:16 AM
Josh Leverington's Avatar
Engine light
Has anyone else gotten a engine light from running a mpx catback exhaust n mpx catless dp?I was crusing at 60km/h n it just came on all of a sudden was not beaten on it at all....
I'm not tuned, n no other mods
Last edited by Josh Leverington; Jun 5, 2010 at 02:16 AM. Reason: Automerged Doublepost
Old Jun 5, 2010 | 08:45 AM
SSlobalt's Avatar
Get the code read and report back.
Old Jun 5, 2010 | 01:09 PM
Explain further I'm not following? Where do I read the codes
Old Jun 5, 2010 | 01:13 PM
TommyP's Avatar
AWD > FWD
Take it to autozone and have them tell you the code. I guarantee though it's due to the catless dp.
Old Jun 5, 2010 | 01:24 PM
Iam Broke's Avatar
^^^^^ Need an O2 bung extender if it doesn't have an angled bung for the rear O2 sensor.
Old Jun 5, 2010 | 01:25 PM
Younggunna's Avatar
Your in Coquitlem... we dont really have shops that will scan your car for codes for free in vancouver, most will charge. Scanning a code is having the shop use a diagnostic tool to find out the cause of the engine light.
That being said, your mostly stock and not tuned so Id go back to the dealership and drop it off there and have them take care of it
hope that helps
Old Jun 5, 2010 | 01:30 PM
That's what I think aswell, should i worry about it? I still have to get my power steering fix at the dealer would they fix it? Or should I keep it hush hush to them
The mpx catless dp has 3 places to put the o2 sensor should I move it to a different spot?
Last edited by Josh Leverington; Jun 5, 2010 at 01:30 PM. Reason: Automerged Doublepost
Old Jun 5, 2010 | 01:35 PM
TommyP's Avatar
AWD > FWD
There should be a spot on that one where there is a piece of pipe coming off of the DP that is angled. Put it there.
Edit. NVM just looked at the pic of it. Doesn't have it for some reason.
They should have done it like the Hahn one they sell
Old Jun 5, 2010 | 01:37 PM
Younggunna's Avatar
if its that o2 sensor thats throwing the code, the dealership will probably charge you for an hour labour plus diagnostic fees and anything else they can think of at that time to tack on the bill and say since your dp is aftermarket, they are voiding that part of the warranty.
Where did you get the dp installed? if at a shop, go back to them and ask them to scan the code for you, post the code on here or find that thread where it lists all the codes, then you will know if its your DP.
If you installed it yourself, maybe grab the best looking girl you know and have her drive your car into a kal-tire or something like that and have her ask the tech about the engine light, most likely they'll scan it for free lol
I wouldnt worry about the engine light too much if your car drives the same, but I wouldnt ignore it either.
Old Jun 5, 2010 | 02:16 PM
I don't see why it should be angled, I am assuming it gets a better reading? Maybe if I shuffle around my O2 sensor I can fix the light
I installed it myself. GM would look at me like a cash cow.. car drives fine no problems at all. Like u said I shouldn't ignore it at the same time
Once the code is thrown if u could fix the problem by yourself does the light go away or u have to get it reset to get rid of the engine light
Last edited by Josh Leverington; Jun 5, 2010 at 02:16 PM. Reason: Automerged Doublepost
Old Jun 5, 2010 | 02:24 PM
Iam Broke's Avatar
It goes away in time, or you can disconnect the battery for ~15 mins to reset it.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
