Explain Launch Control please
Old Jun 20, 2008 | 10:41 PM
ChevySKIDOO's Avatar
Launch control i dont get it.
sorry if this has been asked a thousand times
Explain please?
Old Jun 20, 2008 | 10:42 PM
Cobaltss/TC's Avatar
floor gas dump clutch simple as that while in launch control mode
Old Jun 20, 2008 | 10:48 PM
so just wide open throttle the gas and should it go to redline or is there a set rpm in launch control
is it like 5100 or something?
please explain lol
i got no lift shift figured out did it once and its sick. got one pop to
Old Jun 20, 2008 | 11:01 PM
TurboSS's Avatar
1.. set car to comp mode " this is the same mode you have to be in to do no lift shift "
2.. hold clutch in and floor the gas
3.. the engine program is set to hold at 5100 rpm in this mode
4.. let out clutch smooth and quick
the car will launch and there will be little wheel hop. you can no lift shift or shift norm.
Old Jun 20, 2008 | 11:06 PM
well thank you
Old Jun 21, 2008 | 08:37 AM
thehov's Avatar
yea I still havent tried it on mine yet......
Old Jun 21, 2008 | 08:46 AM
IsItFast?'s Avatar
Dont let the clutch out too quickly - otherwise it bogs and doesnt launch. Once it is held at 5100rpm, just let the clutch out at a normal speed. If you "dump" the clutch it bogs.
Ive actually found the launch control to be gimicy - you can get a better launch doing it yourself. Now the no-lift shift is great
Old Jun 21, 2008 | 10:04 AM
MapOfTaziFoSho's Avatar
All solid advice!
Old Jun 21, 2008 | 12:18 PM
PimpLay2's Avatar
im with "isitfast" i found out launching the car yourself is better...
DO NOT DUMP THE CLUTCH I REPEAT DO NOT ... your car will hop ... then stop then take off you probably wont run better then a 14.7 if you dump it.... just let the clutch off smooth and quick but not to fast that you dump it
I launch the car myself around 3k and i have good launches the tires dont spin and i dont hop... yea i dont launch to fast but i GRIP and thats all that matters and my times are getting better... idk maybe some1 who drives better then me can launch at 5k but I seem to spin almost the whole way to 2nd gear
Old Jun 21, 2008 | 12:37 PM
chevySSgal's Avatar
Ok, sorry for a stupid question but what is "no lift shift?" I have never heard of that except for just buying this car. I hadn't driven a manual for 18 years before this.
Old Jun 21, 2008 | 01:20 PM
Basically it allows you to stay at WOT and shift without lifting off the accelerator. Now, while people have been doing this for years, GM has gone and reprogrammed the ECU to reocgnize that the upshift is coming and automatically adjusts everything to allow you to make lightning fast shifts without damaging your drivetrain.
Old Jun 22, 2008 | 09:06 AM
chevySSgal's Avatar
So it can only be in competition mode for this? I want to try it out today.
Old Jun 22, 2008 | 09:10 AM
steddy2112's Avatar
Seems as though everyone but me thinks so.
I have no lift shifted in regular mode.
No rev limiter bullshit.
Pops, just like in comp mode...but to be safe just put it in comp mode.
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 07:39 AM
metroplex
Sep 27, 2015 07:48 AM
Coballin13
Sep 25, 2015 08:43 AM
