First ss tc
Old Jun 15, 2011 | 08:14 AM
bucks121's Avatar
First ss tc
picked up a 08 ss/tc just got a question how do i use launch control and NLS? what to i need to turn on nd what do i need to do after
Old Jun 15, 2011 | 08:27 AM
CudaJoe's Avatar
Read the owners manual.
Old Jun 15, 2011 | 08:28 AM
cobaltj's Avatar
Ok launch control works off your traction control button. Push it once for tc and again for launch control. It will tell yoi on your dash that your in launch contol. Then just hold your petal to the floor. You should hold steady at 5000rpms. Then just roll the clutch. I personaly think its set to high. Thats why i changed mine to 3500 with my trifecta tune cause 5000 is just to much. As far as nls its pretty self explanatory just hold down the gas and dont lift the throttle when you shift. Hope this helps and enjoy your new car.
Old Jun 15, 2011 | 08:35 AM
Supercharged Guy's Avatar
Push TC button twice...rev up to 5-5.5k whatever it is I forget dump clutch and good to go...
NLS- Keep foot on gas dont let up and shift through the gears...pretty easy
Old Jun 15, 2011 | 09:24 AM
umrdyldo's Avatar
Don't use Launch control unless you hate your car.
Old Jun 15, 2011 | 09:30 AM
dayhoff35's Avatar
make sure your at 6k or more for nls though...
Old Jun 15, 2011 | 10:08 AM
Sweetsandman's Avatar
Originally Posted by umrdyldo
Don't use the stock Launch control unless you hate your car.
Fixed
Old Jun 15, 2011 | 02:00 PM
bucks121's Avatar
i tryed the NLS it just doesnt seem right something makes a really loud squeel and it doesnt seem like it holds the boost maybe i just didnt rev it out high enough?
Old Jun 15, 2011 | 02:04 PM
CSA0890's Avatar
Yeah NLS always felt like it was too rough on the drivetrain. I only did it right after I got it and then stopped.
Old Jun 15, 2011 | 02:49 PM
bucks121's Avatar
from what i read when ur rev it out and put the clutch in to hit the next gear its suppose to cut off the gas?
Old Jun 15, 2011 | 02:51 PM
MastaShaKe_88's Avatar
My NLS has only worked once an it felt like I broke something
Old Jun 15, 2011 | 03:13 PM
bucks121's Avatar
dam i wanna use it maybe im doing something wrong? does anyone actually use theirs often?
Old Jun 15, 2011 | 06:38 PM
SSlobalt's Avatar
I used mine a lot when I first bought the car, when it was still completely stock. I only NLS'd 2 to 3 and 3 to 4. As long as you're up at 6K and you hold the gas pedal all the way to WOT, then it works pretty well. You hold boost, you get a pop, and you go. If you're car is tuned, though, I wouldn't bother. NLS just messes things up when you're tuned.
Old Jun 15, 2011 | 06:45 PM
D-mac's Avatar
Careful using the NLS can eat your trans
Stock Launch control sounds pretty cool but is useless
Old Jun 15, 2011 | 11:43 PM
DirtyBalt09's Avatar
Grats on car.
Old Jun 16, 2011 | 12:53 PM
cobaltj's Avatar
I used my nls all the time until i got a tune. Never had any issues at all. Not sure why others are afraid of it or why they dont want to use it. My service manager told me it was designed to be used or gm woundnt have put it on the car. He said besides if i had any issues just turn it in on warenty. Thats what it for.
Old Jun 16, 2011 | 01:44 PM
RoadconeTuning's Avatar
the NLS slams the throttle closed and kills boost because GM sucks with their TQ management... launch control is a joke on these cars...
either way its a helluva lot faster to just powershift the car than it is to try and be nice to it...
Old Jun 17, 2011 | 07:40 PM
slowbalt84's Avatar
ive NLS'd hundreds of times on a bigger turbo and NEVER had trans problems. if it breaks it breaks but when you need it it really helps
Old Jun 17, 2011 | 07:47 PM
Dart_SI's Avatar
ive used nls hundreds of times with full bolt ons and 20 psi tune without a problem. trans is perfectly healthy. and it makes a big diffrence.
Old Jun 17, 2011 | 08:23 PM
edwardfaria08ss's Avatar
no lift shift should only be hard on the clutch if u do it right. u have to be quick about it. basically your dropping one side of the clutch (trany side) thats moving slower onto the fly wheel which will be moving fast cause of the high reving motor. the clutch slips a little but will catch pretty fast. result u get the feeling of getting pulled into the seat. and no turbo lag.
miss a gear doing this though and say good bye to your transmission.
