Gm Stage 1 kit
Old Apr 30, 2021 | 11:05 AM
DemonboyX21's Avatar
Gm Stage 1 kit
Hello all just wondering is there anywhere that still sells the GM stage 1 kit? Everywhere I've looked so far is out of stock.
Old May 2, 2021 | 04:51 PM
Monieg5gt's Avatar
Try crateengine.com
Old May 2, 2021 | 08:05 PM
Tdubbs's Avatar
Could also see if Pwerks has them.
WERKSracing 3 bar LNF map sensor kit, Performance Autowerks
Old May 3, 2021 | 10:10 AM
ProfDNS's Avatar
Try crateengine.com
CrateEngineDepot.com
CED LNF Stage Kit CEDLNF1
Old May 3, 2021 | 10:30 AM
Kolt's Avatar
The kit with the authorization code required to do the gm stage tune at a dealer is long gone. I'm a dealer tech and I spent extensive time trying to hunt one down for mine to make it legit and had no luck. I just went and bought the plug and play kit with sensors from zzp (cheaper than ced) then found a vin that had the gm stage tune done at a dealer from another user and reprogrammed my car with it. Your only options are is to do the same as I did if you got a friend at a dealer, have someone with hp tuners do a tune after you get the kit, or buy hp tuners for yourself and have fun. The stock and also gm stage tune is out there if you wanna be conservative and have a fallback while you learn it yourself.
https://zzperformance.com/products/gm-stage-1-sensors
Old May 3, 2021 | 08:05 PM
mholstein's Avatar
Kolt, sounds like you have this answer available for copy/paste. I had asked this too recently only because CA smog requires a stock tune. I just decided to keep my stock sensors and flash back to stock via HPT every 2 years. The better solution would have been to not have sold my old one that had the factory GMS1.
Old Oct 17, 2025 | 11:56 PM
spaz's Avatar
Did your car run with the incorrect vin
I want to do this. I do have a gmpp stage tune but the vin is different obviously not my car. I’d I load it into my car will I have any issues with the vin not matching.
dis it work for you?
Old Oct 22, 2025 | 03:21 PM
DeanSsspsh's Avatar
I've have 2 different pcm's that have a different vin than the car i own. My last 08 chevy cobalt ss was t-boned by a Tesla. I since bought another 08 Chevy cobalt ss & can successfully use the last cars computer that has a different vin #. I just had to do a security relearn. To do the security relearn, follow the instructions on zzp's website.
Old Oct 23, 2025 | 11:16 AM
spaz's Avatar
It worked. I did have to license my car and the tune so it cost me 4 credits. The ecm doesn’t care what vin is on the tune. I didn’t even have to relearn the security.
trec2cobalt
Jul 30, 2010 03:37 PM
395 plus
Oct 12, 2009 03:36 PM
agent007kimball
19
Nov 19, 2008 05:49 PM
